2.8L to 5.7L engine swap???
Old Jul 11, 2005 | 08:33 PM
  #16
Joe3's Avatar
Re: 2.8L to 5.7L engine swap???
I forgot to ask. Its the same tranny as the 305s have except for the bell housing, If I put a 350 or a 305 in and change the bell housing, do I also have to change the tranny mounts, or will it sit right where it needs to be as it is????????? Also again, can my t-5 handle a 350??????
thanks,
Joe
Old Jul 12, 2005 | 06:44 PM
  #17
Joe3's Avatar
If I put a turbo400 or a 700 tranny in with a 350 carb motor, do I need a computer at all?????
Old Jul 12, 2005 | 08:35 PM
  #18
confused327's Avatar
nope
Old Jul 13, 2005 | 06:47 PM
  #19
Joe3's Avatar
are you sure??? And does anyone know a manual trans I could put in to avoid the use of a computer????
Old Jul 13, 2005 | 07:08 PM
  #20
masiroc566's Avatar
Well!! Speaking from experience I did exactly what you want to do. I pulled the lightweight out and put a heavyweight in. I went carb with a EDL-1406 non emissions you will probably need emissions EDL-1400. I basically deleted the function of the computer as far as the motor goes. I placed shorty headers on it(wrapped them too). Bought a LS1 T56 that is without the use of the fork...the best for you would be with the fork. I have an aluminum driveshaft, auburn posi limited slip with 3.73 gears. The clutch is a Centerforce. Had to do some modifications cutting the floor board about 1-2 inches toward the rear. Changed the springs and shocks. You will also need a new Torque arm if you go with a T56. Crossmember also. It is a challenge especially if you do it yourself as I did...wiring too.
Old Jul 14, 2005 | 07:42 PM
  #21
Joe3's Avatar
Im in Wisconsin, we dont have emissions inspections...
Old Jul 14, 2005 | 08:33 PM
  #22
masiroc566's Avatar
Does your car come with A/C? Get yourself the V8 motor that you wish. You will need the V8 motor mounts. Buy a Haynes or Chilton manual and it will help you in the mounts placement. See if you can get a hold of some serpentine brackets from a V8 motor. You will need a setup like this one http://gmpartsdirect.com/results.cfm...umber=12497698 .
You can find this stuff used from ebay or even on this site. Or if you need I can supply you with a guy I know in South Carolina that has a Camaro graveyard.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rocketman051894
Jan 30, 2015 03:23 PM
rockync7
Jan 1, 2015 05:10 AM
Cam28_boy
Aug 6, 2002 08:40 AM
