2.73's to 3.73's
Old Mar 6, 2004 | 04:38 PM
f-bodybuilder's Avatar
2.73's to 3.73's
If my car's runnin a 15.9 in the quarter with my crappy 2.73's, what'll i be running with a 3.73 rear?
Old Mar 6, 2004 | 05:03 PM
unvc92camarors's Avatar
really, traction will determine if it will help any seeing as you need that to put the gears to use
but assuming you can hook up decently, i say anywhere from .2-.5 or so
Old Mar 6, 2004 | 07:53 PM
lordmetalz28's Avatar
really, has anyone had any firm drops by switching caus eim switching to 373 soon i have michellen pilots so ill have decient tractions
Old Mar 6, 2004 | 08:05 PM
well, i think this could get more replies in the drivetrain forum
but, since you guys have autos, i think a higher stall converter is what a lot of people would reccommend
Old Mar 6, 2004 | 08:42 PM
haha my bad i have the engine tech forum set as my homepage and sometimes i forget there are other forums...... when my bro switched from 2.41's to 3.42's in his 77 firebird he went from runnin a 15 to a 14 flat. i was just wondering if the gains might be the same.
Old Mar 7, 2004 | 02:49 PM
Willie's Avatar
Have you found 3.73's yet? I just happen to have a set of GM 3.73's for sale. The GM's make absolutely no noise and are very hard to find.... Less than 20,000 miles.... I really like them but the reason I need to sell is because I went to 3.23's. Run out of top gear at around 115 mph with 3.73's (at the track of course!).
Old Mar 7, 2004 | 05:47 PM
aklim's Avatar
What do you have to have for it because someone I know of might be interested,
Old Mar 7, 2004 | 10:45 PM
Actually there's a ton of junkyards by where i live filled with thirdgens, so I'm gonna try my hand at finding a complete 3.73 posi rear before i spend the $$$$ to install some. Doesn't anyone have any times from before and after this same swap? There has to be SOMEONE.
Old Mar 7, 2004 | 11:52 PM
AutoRoc's Avatar
I did the 3.08 to 3.73 gear swap but did a lot of other stuff at the same time so I can't get you any solid numbers. I think you'll see a good gain only if you have enough traction. 3.42 would be a better choice I think. 3.73 seems to be too steep from the last 2 setups I had. I just went to a 28" tall rear tire and it's helped a lot to get me back down into the powerband if that makes any sense..haha
Old Mar 8, 2004 | 12:44 PM
StalkerIROCZ's Avatar
HOw much are you wanting for them? I have a rear end outta like a 83 or 82 Camaro its a 12 bolt with rear disce being the reason i bought it b/c Who ever bout my Iroc didnt get rear disc in the back BUt anyway i am interested in these gears So shoot me a price and if you could get me a part number so i can see if they will sawp out.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
