1LE or not?
Old Jun 12, 2008 | 02:03 PM
wookey's Avatar
1LE or not?
Can you tell if a 1991 camaro is a special edition, 1LE, from the vin #. If so here it is an tell me what you think 1G1FP23F7ML13820
Old Jun 12, 2008 | 03:56 PM
DAKMOR's Avatar
No. Not from the VIN. In fact, If I'm not mistaken, and without looking at any resources, that's a TPI 5.0L.
You need to look at the RPO codes to see if it's a 1LE.
Is this your vehicle or something you are looking at purchasing?
EDIT: oh, and you're missing a digit..
Old Jun 12, 2008 | 04:00 PM
rik89gta's Avatar
Couple questions for Ya...
Is it a 5 speed? Does it have dual catalytic converters? Does it have bigger 11.6 inch front rotors? Does it have an aluminum spare tire in the hatch? These are a few of the telltale signs that You may have a 1LE.
Old Jun 12, 2008 | 04:22 PM
detltu's Avatar
Rear disc brakes also. Although it could be a B4C or just a G92 with the rear discs
Old Jun 12, 2008 | 04:51 PM
rik89gta's Avatar
Yes it is a 305 TPI as denoted by the f in the vin. But I'm pretty sure you could get the 1LE package with the 305 tpi and 5 speed combo.
Old Jun 12, 2008 | 05:32 PM
wookey's Avatar
It is auto with overdrive. Pretty run down so i'm not sure about the other parts. Current owner is convinced it is 1LE. Based your feed back I'm thinking NOT a 1LE.
Old Jun 12, 2008 | 05:34 PM
wookey's Avatar
your right I am miising a # 1G1FP23F7ML132820
Old Jun 12, 2008 | 07:07 PM
rik89gta's Avatar
You have a lame 305 TPI/A4 combo. It puts out 195 hp and 290 lb ft. of torque. It probably has 2.73 gears too. Don't get me wrong it's got some decent low end grunt but it's not the combination that would even allow for the 1LE package. The car needed to be a 350 TPI or a 305 TPI/T5 combo to even consider the 1LE option.
Old Jun 12, 2008 | 07:14 PM
wookey's Avatar
Thanks guys...the help was much appreciated
Old Jun 14, 2008 | 01:04 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Actually its 210 HP for 90-92 305 TPI automatics. And 1LE's have no air conditioning, no power locks, no power windows, and no foglights.
And as Rik said, it has to be a 350/auto or 305/5-speed to be a 1LE.
Old Jun 14, 2008 | 02:29 AM
rik89gta's Avatar
Hey Kevin! I recognize You from thirdgen.org... But anyways are You sure that the 305/A4 combos made more than 200 hp stock? My buddy had a 91 Ta with the 305 TPI/A4 and it was a speed density motor. My 87 305 TPI/A4 TA had the same peanut cam with MAF and we both had 2.73 gears. We both ran neck and neck. We ran really close to each other. Our buddy with a bone stock 83 H.O. ran us both down! I don't know if it was the 3.73 gears on that car that did it,,,,, But damn it was quick!!!
Old Jun 14, 2008 | 06:44 PM
1987IROC350's Avatar
My Camaro White Book shows 205hp for auto. Manual got 230hp since dual cat was mandatory.
Info from: Camaro White Book printed 2003. Info on 67-02
Old Jun 15, 2008 | 09:49 PM
Bristol's Avatar
Sorry but this is not entirely true. I have a 91 1LE with both power windows, mirrors and door locks. You are correct about the AC and fogs.
Crappy scans but hopefully you can see that a 1LE car can have options. Also any dealer can print theRPO codes. I had my local parts dept. print these off a couple years ago.
Old Jun 21, 2008 | 11:09 PM
Kevin91Z's Avatar
My mistake, its 205 HP. You do NOT have a peanut cam. Only 88-89 305 automatics have them. 87's do not and 90-92's do not. Yes its probably the 3.73 gears that caused him to run you guys down, plus the better exhaust. The 88-92 305/automatics have the tiny TBI exhaust, while the HO cars have the better bigger exhaust.
I've never heard of a 1LE having power options, but I guess anything is possible.
Old Jun 22, 2008 | 11:26 AM
Bristol's Avatar
Yah I guess most 1LEs dont. Just odd cause my buddies old 92 Z28 with the 350 auto combo had the 1LE package too along with leather. Maybe its a Canada thing lol
Kinglouui
May 26, 2016 11:05 AM
force10
Jul 30, 2015 04:56 PM
Jlo
Jul 29, 2015 03:52 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
gto4u2
Mar 14, 2015 06:05 AM
