1992 Camaro Z28 Tpi, Mods???
Old Dec 27, 2003 | 01:58 AM
Ville H. Valo's Avatar
I Just got a 1992 camaro z28 with an LB9 TPI. what are some good mods for some seroius preformance that are 50 state legal?
Old Dec 27, 2003 | 02:04 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
cat-back exhaust, heads, cam, intake manifold, runners, headers, throttle body, etc.
Old Dec 27, 2003 | 02:38 AM
What would add the most power, i was looking at a stealth ram, but i live in california and i dont think it is emmisions legal.....
Old Dec 27, 2003 | 05:59 AM
97WS6SCharged's Avatar
Supercharger. It's emissions legal and will add lots of power.
Old Dec 27, 2003 | 08:30 AM
millican's Avatar
Your right, the HSR isn't emmisions legal. You will benifit most from a complete exhaust package, this should include headers and a cat-back system. You will love the sound too over stock.
Old Dec 27, 2003 | 04:19 PM
aklim's Avatar
See my sig.
Old Dec 27, 2003 | 08:41 PM
I think i am going to get the HSR anyways, when i have to get the car smogged in a year and 9 months i will just change it back to stock, i think that the HSR will give me some good performance for a little bit of $$$. Changing the whole exaust system is to costly....
Old Dec 28, 2003 | 01:44 AM
Kevin91Z's Avatar
Ok, so you add a great flowing big intake, but your cam is too small, your exhaust is too small, your stall converter is too small, and your rear end gears are too tall. That great intake will become a dog on your engine because your comination is out of whack.
The best place to start on thirdgens is with the exhaust. Then add a set of subframe connectors.
Old Dec 28, 2003 | 01:53 AM
so you suggest i dont get the intake because it won't work properly, pretty sure they designed it to work with the stock sys. what do you think?
Old Dec 29, 2003 | 02:13 AM
Kevin91Z's Avatar
Did you see this thread:
http://web.camaross.com/forums/showt...hreadid=207375
I'm only saying the intake is not the first thing you should swap, the exhaust is.
Old Dec 29, 2003 | 06:23 PM
ok what would you suggest? i need 50 state legal headers and cat back, what should i buy....
dont want to spend alot......
Old Dec 29, 2003 | 06:50 PM
aklim's Avatar
You get what you pay for. Sure, you could use Edelbrock TES but they aren't as good as say SLP or Accel Tri-Ys which are no longer made. I paid a bunch for the Accels but they lasted very well and were ceremic coated. Believe me, you cannot afford cheap junk. I bought TFS heads because they were cheaper than AFRs. They were much more expensive in the end when I had to replace my LPE 383 SB which was screwed up when the piston hit the valve and the fragments hosed up cylinder #4. The few hundred I saved did not even cover the repair costs or the downtime.
Old Dec 30, 2003 | 12:15 AM
Kevin91Z's Avatar
Headers for you I would recommend the Hooker 2055's, a CarSound catalytic converter, and any true 3" cat-back exhaust and muffler you like.
Once you do that, then I'll let you swap on the Holley Stealth Ram.
Old Dec 31, 2003 | 12:38 PM
305fan's Avatar
Is it 5 speed? Dual or single cat?
They all got the same (good cam) for that year, regaurdless of transmssion.
Unless you want it to be super fast--stick with the stock cam for now.
Old Dec 31, 2003 | 03:13 PM
reply
it is a 5 speed, single cat
