1991 Rs
Old Jan 13, 2003 | 07:37 PM
99huggerorangeZ's Avatar
Question 1991 Rs
i have a 1991 RS and i am looking to replace my stock axles with a set of Moser axles but i am not sure what spline i will need
Old Jan 16, 2003 | 03:57 PM
ebmiller88's Avatar
'90 and up years are all 28 spline.
Ed
Old Jan 16, 2003 | 08:37 PM
87DJP2001's Avatar
Why are you replacing the axle shafts on a RS????
Old Jan 16, 2003 | 10:12 PM
i just preplaced my 305 with a 377 that is puttin out 450HP and close to 500LBS of TORQUE so i want to upgrade my rearend so it can take the power and abuse
Old Jan 17, 2003 | 07:20 AM
87DJP2001's Avatar
If you have that much HP/TQ I would be concerned about the whole 10-Bolt rear end. And your RS should have the 28 spline axle shafts already & just the shafts will not be that much help for the cost. My opinion.
Old Jan 17, 2003 | 10:08 AM
aklim's Avatar
I have mine worn out. Next time there is a problem, I will be changing to a 9in Ford. My end caps are not seating just right and the bearing on the left side of the posi is not snug. We had to dimple the posi and use adhesive because we were trying to get it out then. If it breaks again which I am sure it will, I will have a custom 9 in unit by Moser.
Old Jan 17, 2003 | 10:13 AM
Chuck!'s Avatar
Sounds like a sweet engine. Id love to build a 377, would you disclose your mod list for inquiring minds?
Old Jan 17, 2003 | 10:31 AM
aklim's Avatar
377?? Isn't that a 383 without the boring, ie a stroked 350?
Old Jan 17, 2003 | 12:26 PM
TheGreatJ's Avatar
A 377 is a stock bore 350 with a 3.75" stroke crank.
I personally wouldn't run a 10-bolt behind an engine with 500lbft, I'd go with a 12-bolt or 9 inch....but if thats out of your price range then even a BW 9-bolt would be better than the 10-bolt rear. With that kind of torque you can expect to grenade the diff pretty quickly. Especially if you're running a manual tranny.
Old Jan 17, 2003 | 12:51 PM
Chuck!'s Avatar
I was under the impression that a 377 was a destroked 400. 4.125" bore with a 3.48" stroke. High *** reving engine.
Old Jan 17, 2003 | 02:09 PM
TheGreatJ's Avatar
A stock- bore 400 destroked to 3.48" is a 372. You can bore it .030 and that's one way to get 377 cid.
Old Jan 17, 2003 | 02:17 PM
aklim's Avatar
I have seen cars with A4 trans work with that much power. You'd have to have something to hold down the end caps and support the rear end with some sort of girdle.
M5 or M6 trans kills the rear end, I suspect, because of the 5000 rpm launch.
Old Jan 17, 2003 | 10:37 PM
377ci
4bolt mains-ARP STUDS
4.000" bore
3.50" stroke
6.0" rods
Parts Include:
JE Forged 10.3:1 Pistons
Eagle 4340 Forged Crankshaft
Eagle ESP 6.0" Rods
BG Demon 750
Edelbrock Air Gap Manifold
Edelbrock Victor Jr 70cc Cylinder Heads
Hooker Supercomp Headers w/ Jet Hot Coating
LT4 Hot Cam .525/.525 Lift w/1.6 roller rockers
Comp Pro Magnum Roller Rockers
Comp Hi-Tech Pushrods
Comp Roller Timing Chain
Holley Pro series Mechanical Fuel Pump
BG Fuel Regulator
Milodon Stoker 7qt oil pan w/ high volume pump
milodon windage tray
Old Jan 17, 2003 | 11:15 PM
91 Redd Sledd's Avatar
Why not run a Ford 8.8 rear Every one overlooks these for the 12 bolts and the Ford 9'. 8.8's are not much weaker if any compared to the 9'.I have heard of a few LS1 M6 guys running them with great sucess and they are cheaper too.Also look at all the fox body Mustangs running 9's and 10's on there 8.8's.Just my .02.
James
Old Jan 18, 2003 | 09:26 AM
gs400tx's Avatar
8.8"..
what about issues like panard bar mount and spring perches. Without someone who has welded these up,, its a trial and error job. Any of these being mass produced?
