2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
New Tire on Same Wheel Loses Pressure.
Old Sep 26, 2011 | 10:52 AM
Kurt Crosbie's Avatar
Just purchased two new tires recently after my LR kept going flat. I am now experiencing that same problem on the same wheel with a new tire. The wheel itself looks like its in fine shape. I don't see any curb rash on it or bends. What are the chances I purchased another tire with a leak in it? What should I be looking for?
Old Sep 26, 2011 | 11:02 AM
JasonD's Avatar
Admin Emeritus
Re: New Tire on Same Wheel Loses Pressure.
Odds are slim the tire is bad. Odds are good the wheel is bad.
Just the slightest variance in the wheel can make it leak, including corrosion around the bead area, it being slightly out of round, etc.
How fast does it lose air?
Old Sep 26, 2011 | 12:34 PM
Takes 2-3 days. Guess I will buy a new wheel.
Sent from my SCH-I800 using Tapatalk
Old Sep 26, 2011 | 12:57 PM
JasonD's Avatar
Admin Emeritus
Stock wheel? Take it back to the dealership, it should still be under warranty unless you put a lot of miles on it since 2010.
Old Sep 27, 2011 | 02:20 PM
I don't know if it was corrosion, but it looks like the chrome had built up in some areas where it meets the tire. Never seen anything like that before. Is it common?
Sent from my VS910 4G using Tapatalk
Old Sep 27, 2011 | 02:48 PM
SSCamaro99_3's Avatar
Tire Pressure sensor could be an issue. My brother had this on his Jeep. Brand new tires losing air.
Old Sep 27, 2011 | 03:22 PM
I don't think 95's had tire pressure sensors.
Old Sep 27, 2011 | 03:28 PM
JasonD's Avatar
Admin Emeritus
In that case, I don't think you meant to post your thread in the 2010 - 2011 - 2012 Camaro Wheels, Tires, Brakes, Suspension forum.
Old Sep 27, 2011 | 04:12 PM
Oops
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Jason Short
Jan 19, 2015 06:33 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
