2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
2015 z28 carbon ceramics and wheels
Old Mar 11, 2015 | 02:39 AM
carguy0119's Avatar
Hey guys so new to the camaro world. I actually don't have one but I need some part numbers if u guys could help a brotha out! I have a 98 grand prix that I am building going to be putting the z28 carbon ceramic brakes on it. I have a part number for the front rotors but i still need numbers for front calipers. Rear rotors and calipers and part numbers for wheels and tires front and rear. Also I don't know how accessible the information will be but if possible I also need weights for all these parts. My biggest reason for doing this is weight reduction. So I wanna make sure I'm not gaining more weight in wheels and tires than I will be dropping in brakes. All the guys in my grand prix forum are being *******s and not very helpful so any help u guys could lend is much appreciated!
Old Mar 11, 2015 | 06:53 AM
Re: 2015 z28 carbon ceramics and wheels
Not a lot of 5th Gen members here..... not sure if you will get the detailed response you need.
Old Mar 13, 2015 | 06:24 PM
JakeRobb's Avatar
Super Moderator
Like Fred said, probably not many people here who know the answer to your question.
That said, I'm pretty sure I heard that dealerships are restricted from selling Z/28 parts to people unless it is for the repair of a Z/28. You can, however, order the brake upgrade kit from GM Performance Parts.
What size wheels do you have on your GP? They'll need to be at least 19" to clear the Z/28 rotor/caliper combo.
Old Mar 13, 2015 | 06:51 PM
JakeRobb's Avatar
Super Moderator
I was wrong. There are a lot of Z/28 parts available from GMPP, but the carbon brakes aren't one of them (yet!).
Worth pointing out: expect such a kit to be $15-20k.
Old Apr 11, 2016 | 11:11 PM
Z28SORR's Avatar
These parts are highly restricted to Z28 owners. You must have a VIN number to order parts in most cases. However the brakes are brembo's, so you could check there site. The fronts are 19X11 and the rears are 19X11.5 so you'll need to check the clearence. The wheel studs are also larger. The wheels are light weight aluminum. I have seen replica wheels, but don't know the specs.
Feffman
Oct 9, 2015 05:42 AM
NewsBot
Jan 11, 2015 06:10 PM
Dec 4, 2014 11:56 AM
NewsBot
Nov 25, 2014 11:20 AM
ChrisFrez
Nov 23, 2014 10:33 AM
