V8 Camaro Performance Upgrades
Old Apr 5, 2009 | 04:10 PM
Milk 1027's Avatar
Hey guys I'm new to the forum but I frequent other Camaro forums.
I started this thread at Camaro5 then carried it over to 5thgen, so now I bring it to you guys.
If you can contribute by posting links to other upgrades it would be appreciated.
This is just the V8 thread I have also posted a V6 thread in the V6 forums
V8 (LS3, L99)
Headers:
GMPP shorty headers:
http://www.gmperformanceparts.com/se...o_sitelet.html
$1000
part number: 92213295 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Borla T-304 steel headers:
http://www.jegs.com/i/Borla/157/17249/10002/-1, http://store.summitracing.com/partde...5&autoview=sku
$915.99
Catback exhaust:
GMPP catback exhaust system:
with tips $950 part number: 92206992
without tips $750 part number: 92225672 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
GMPP Track Pack (off-road only):
part number: 92231570
Borla GM catback exhaust system + X pipe:
http://www.borla.com/applications/lo...X_pipe/140280/
part #140280
$1,449.99
http://www.borla.com/applications/lo...X_pipe/140281/
part #140281
$1486.99
Magnaflow Street Series:
http://www.magnaflow.com/02product/s...one=all&id=121 2.5 in. system, Dual Split Rear Exit.
part number: 16579
http://www.magnaflow.com/02product/s...one=all&id=123 2.5 in system, Axle-back, Dual split rear exit.
part number: 16581
Magnaflow Competition Series:
http://www.magnaflow.com/02product/s...one=all&id=122 2.5 in. system, Dual split rear exit.
part number: 16580
http://www.magnaflow.com/02product/s...one=all&id=124 2.5 in. system, Axle-back, Dual split reaer exit. part number: 16582
Air Intakes:
GMPP Air Intake:
$450 part number: 92212302 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Street I
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price: $349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au...&Level2=CAMARO
Sport Package
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price: $699.99 with package, $891.15 individually
Camaro Street II
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price: $1,299.99 with package, $1582.42 individually
Camaro Track II
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price: $2,999.99 with package, $3,372.56 indidvidually
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38144.140 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Sportline Kit (extreme lowering springs):
part number: 4.14438 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Anti-Roll-Kit (Both Front & Rear Bars):
part number: 38144.320 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Old Apr 5, 2009 | 04:11 PM
Milk 1027's Avatar
Shifter
Hurst Short Throw Shifter: http://www.gmperformanceparts.com/se...o_sitelet.html
$300 part number: 92214388 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Brake Systems
*1Baer Complete System (Pro-Plus):
http://www.baer.com/products/complete/pro-plus.php
6 piston calipers and 13” or 14” slotted, drilled and zinc washed, 2 piece rotors.
*Will fit under 18 inch wheels.
Price: $1820.95 for complete front system, same for rear system.
Tune
*5Tune Time Performance:
http://www.tunetimeperformance.com/z...ain_page=index
Costum dyno tunes
Packages
*5MAST Motor Sports 2010 Camaro Track Packages:
http://www.mastmotorsports.com/page....ackages&id=117
Fast - Stage I Stage Strip Package
"525 Flywheel HP"
• Mast L99 VVT Phaser series cam for auto trans. Camaro SS
• Mast LS3 Single Bolt series cam for manual trans. Camaro SS
• Mast premium nitrided valve springs
• Brings your Camaro alive with a nice noticeable lopey idle
Options and Upgrades
• EFI Live AutoCal Module with Mast Motorsports Calibration
• Muscle Rods long tube headers
• Muscle Rods exhaust systems
• Mast Black Label high flow fuel rails
• Mast Black Label roller rocker arms
Mast Motorsports recommends that every cam install using stock controller is accompanied by a calibration tune using HP Tuners, EFI Live, or equivalent software. Calibration is available from Mast Motorsports.
http://www.mastmotorsports.com/page....ackages&id=114
FASTER - Stage II Track Package
"545 Flywheel HP"
• Provides a more aggressive idle and the power to get you down the track quicker
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=115
FASTEST - Stage III 12 Deg Competition
• Mast Black Label LS3/L99/L92 cylinder heads (rocker arms not included)
• The same gains as Stage II with the addition of Mast Motorsports Black Label LS3/L99/L92 cylinder heads for the ultimate in 2010 Camaro performance (cylinder head flow data and horsepower ratings coming soon)
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=116
Turbo
*7Aerocharger:
http://hiperturbo.readyhosting.com/store/product24.html
coming soon.....
more to come..............
Coming soon!!:
*3Kenne Bell Superchargers
SLP Performance parts
LPE Performance parts
Harrop Superchargers........ performance parts?
Pfadt suspension parts
*3Magnuson/magnacharger
Kooks headers
American Racing headers
STS Turbo??
Procharger
Corsa Exhaust
*4Varam
*4MGW
*4Spin Tech
*2SSBC
Vortech
K&N
ADM Performance
*6AEM intakes
WARNING: Prices are subject to change. Check here for dealer prices on GMP parts. http://www.gm.oeaccessories.com/Home/
P.S. If anyone finds other upgrades for the Camaro please post the link and I'll edit this post.
Credit:
*1: XanthosV6
*2: FoxMarketingCars
*3: blackedout010
*4: POWERFREAK
*5: Matt TuneTime
*6: Ken AEM
*7: VictoryRed08
Old Apr 5, 2009 | 04:14 PM
Milk 1027's Avatar
reserved
and I meant to post this in the aftermarket discussion, sorry.
Old Apr 5, 2009 | 07:16 PM
JasonD's Avatar
Admin Emeritus
Excellent research. Stuck to the top!
Old Apr 14, 2009 | 05:10 PM
DBSaints's Avatar
+1 you have really done your homework
Old Apr 14, 2009 | 09:18 PM
Milk 1027's Avatar
thanks. I just fixed the Magnaflow links and, added a Turbo system from Aerocharger.
No pricing on it yet but I will update as soon as I find out.
Old Apr 15, 2009 | 09:06 PM
fast34me's Avatar
This Month's Hot Rod Issue
Just got my June issue of Hot Rod, and Mast Performance's 500hp cam and valve springs for the LS3 are in there. So is the Hurst short throw shifter.
I took a look at Mast's website. It's impressive. Thanks for the links.
Old Apr 18, 2009 | 12:57 AM
Logansneo's Avatar
It's amazing to know that with a cam, valve springs, and cpu tuning you can get 525 hp out of the LS3! And with underdrive pulleys, less restrictive exhaust and cold air kits I would imagine the LS3 capable of nearly matching the CTS-V's LS9 power ratings without a supercharger! Guess I know what's going into my 67 one day!
Old May 4, 2009 | 09:20 AM
Camaro_Nut's Avatar
Re-Sticky please?
Old May 4, 2009 | 01:23 PM
JasonD's Avatar
Admin Emeritus
I am not sure how it got unstuck.
Old May 23, 2009 | 05:53 PM
z71collector's Avatar
Hennesey performace makes a long tube header for 1.8k,and a cold air set up for 450.00 I think? They also have a programmer in the works
Old May 23, 2009 | 05:57 PM
I forgt an s in hennessey. They claim a 12hp gain on the cold air unit alone.
Old Jun 20, 2009 | 02:38 PM
southern speed's Avatar
stainless works has headers and 3" exhaust
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
