V6 Camaro Performance Upgrades
Old Apr 5, 2009 | 04:18 PM
Milk 1027's Avatar
Hey guys I'm new to the forum but I frequent other Camaro forums.
I started this thread at Camaro5 then carried it over to 5thgen, so now I bring it to you guys.
If you can contribute by posting links to other upgrades it would be appreciated.
This is just the V6 thread I have also posted a V8 thread in the V8 forums
V6 (DI LLT)
Headers
*1Holden Commodore VZ Long Tube tuned headers:
http://www.bestmufflers.com/bshop/pr...95d4b7d61b5671
Part number: PH5069
Price: $505.00
*1Holden Commodore VE Shorty Headers:
http://www.bestmufflers.com/bshop/pr...233709a36adb98
Part number: PH5080
Price: $440.00
Exhaust
GMPP exhaust system:
http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
With tips: Part number: 92206990
without tips: Part number: 92225673
Magnaflow:
http://www.magnaflow.com/02product/s...zone=all&id=40 2.5 in. system, Dual split rear exit.
part number: 16583
Magnaflow:
http://www.magnaflow.com/02product/s...zone=all&id=41 2.5 in. system, Axle-back, Dual split rear exit.
part number: 16584
Air Intake
GMPP Air intake:
part number: 92212304
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Steet I
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price: $349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au...&Level2=CAMARO
Sport Package
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price: $699.99 with package, $891.15 individually
Camaro Street II
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price: $1,299.99 with package, $1582.42 individually
Camaro Track II
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price: $2,999.99 with package, $3,372.56 indidvidually
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38143.140 http://eibach.com/cgi-bin/htmlos.exe/02784.2.4116424451400009395
Sportline Kit (etreme lowering springs):
part number: 4.14338 http://eibach.com/cgi-bin/htmlos.exe/02784.2.4116424451400009395
Old Apr 5, 2009 | 04:19 PM
Milk 1027's Avatar
Shifter
Hurst Short Throw Shifter:
Part number: 92214389
Brake Systems
*1Baer Complete System (Pro-Plus):
http://www.baer.com/products/complete/pro-plus.php
6 piston calipers and 13” or 14” slotted, drilled and zinc washed, 2 piece rotors.
*Will fit under 18 inch wheels.
Price: $1820.95 for complete front system, same for rear system.
Forced Induction:
Superchargers:
*1Holden, Non-intercooled, 4-6psi Kit:
http://www.capa.com.au/kits_holden_vzv6.htm
price: $4,995.00 AUD
NOTE: CAPA Piggy Back ECU Required: $595.00 AUD
NOTE: 5-6psi Requires Fuel Pump & FMU: $995.00 AUD
*1Holden, Intercooled, 4-7psi Kit:
price: $6,595.00 AUD
*1Holden, Intercooled with fuel system, 11psi:
price: $11,900.00 AUD
*1Raptor Supercharger (Pro Street) 9psi:
http://www.raptorsc.com.au/kits.php?id=37
price: $5,500.00 AUD
more to come..............
Coming soon!!:
*3Kenne Bell Superchargers
SLP Performance parts
LPE Performance parts
Harrop Superchargers........ performance parts?
Pfadt suspension parts
*3Magnuson/magnacharger
Kooks headers
American Racing headers
STS Turbo??
Procharger
Corsa Exhaust
*4Varam
*4MGW
*4Spin Tech
*2SSBC
Vortech
K&N
ADM performance
*6AEM
WARNING: Prices are subject to change. Check here for dealer prices on GMP parts. http://www.gm.oeaccessories.com/Home/
P.S. If anyone finds other upgrades for the Camaro please post the link and I'll edit this post.
P.P.S.: Now adding info for superchargers and turbochargers.
I NEED HELP FROM MORE KNOWLEDGABLE PEOPLE ON THIS SUBJECT!!!
Credit:
*1: XanthosV6
*2: FoxMarketingCars
*3: blackedout010
*4: POWERFREAK
*5: Matt TuneTime
*6: KenAEM
Old Apr 5, 2009 | 04:20 PM
Milk 1027's Avatar
reserved
Old Apr 5, 2009 | 07:15 PM
JasonD's Avatar
Admin Emeritus
Good stuff! Stuck!
Old May 14, 2009 | 02:12 PM
Silverado27's Avatar
From: I was born and raised and reside in Philadelphia, PA.
Just saw this now...Great post man!
Old Oct 8, 2009 | 07:31 PM
1LTV8's Avatar
Still looking for info on ring and pinion size for both v6 and v8 cars and if any different ratio's are out there yet?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
