RevXtreme's RPE800 Twin Turbo 2010 Camaro Upgrade
Old May 27, 2010 | 05:13 AM
RevXtreme's Avatar
Junior Member
Boost your new Camaro's output nearly double with the explosive performance of a twin-turbo 415cid stroker. The RPE800 is the latest American V8 to harness RevXtreme Performance & Engineering’s legendary track record of building high-horsepower, turbocharged muscle for outstanding performance gains.
Power:
• 810 HP
• 782 lb-ft TQ
RPE800 Upgrade Package Includes:
• 415CID Stroker Engine
• Forged Low Compression Pistons
• Forged Steel Connecting Rods
• Callies 4340 Forged Steel Crank
• Balanced and Blueprinted
• ARP Main Studs & Head Bolts
• Ported Cylinder Heads w/ Valves & Valve Job
• RPE800 Custom Spec Camshaft
• Melling Oil Pump
• RevXtreme 90mm Throttle Body
• Ported Intake Manifold
• Upgraded Fuel Injectors (Plus 8 Secondary Injectors)
• Upgraded Fuel System (Includes Lines, Rails & Secondary Pump)
• Twin Ball Bearing Turbochargers
• Dual Waste-gates
• Boost Controller
• Stainless Steel Turbo Manifolds
• 3 inch Stainless Steel Exhaust
• High-Flow K&N Air Filters
• Professional Installation
• Dyno Tuning & Road Testing
• RPE800 & RevXtreme Badging
• Limited Edition Dash Plaque & Engine Plaque w/ Serial Number
• Optional 1 Year / 12,000 Mile Limited Warranty
REQUIRED TRANSMISSION UPGRADE
• 6spd Manual: Twin Disc Clutch
• Automatic: Performance Build & Torque Converter Upgrade
Additional Appearance and Performance Options
for the RPE800 also Available
• Exterior Graphics Package
• 2 or 3 pc Lightweight Wheels
• Full Coil over Suspension Kit
Carbon Body Kit
Call RevXtreme Performance & Engineering Today at (941) 755-3535 for More Information.
Package components and availability subject to change.
Old Jun 28, 2010 | 02:55 PM
MileMan402's Avatar
Are those hp/tq numbers at the crank? Seems kinda low for a stroker? What fuel and boost?
Sent from my Droid using Tapatalk
Old Jul 23, 2010 | 03:11 AM
RevXtreme's Avatar
Junior Member
dont know yet, we have been having problems with the 2010 camaros. so for now (while we are still in business) we will only be doing exhausts.
Old Jul 30, 2010 | 05:42 PM
JasonD's Avatar
Admin Emeritus
What kind of problems?
Old Aug 2, 2010 | 08:40 AM
2010_5thgen's Avatar
thats a not a good a.....
Old Aug 3, 2010 | 10:12 AM
supernova1972's Avatar
So you post up HP/TQ numbers but dont know if that is at the crank or wheels?
Old Aug 19, 2010 | 08:53 PM
Richy_Rich's Avatar
Images?
LeftoverChinese
Jan 14, 2024 03:03 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
grendal
Apr 15, 2010 05:20 PM
