Possible GTO-like engine situation?
Old Mar 18, 2008 | 07:56 PM
  #16
HAZ-Matt's Avatar
Originally Posted by TrickStang37
I agree with that 100%. That, and "freak" (incorrect/manipulated) dyno's.
Nobody wants to talk about dynos inaccuracies and imprecision on the internet, especially bolt on manual owners
Old Mar 18, 2008 | 08:27 PM
  #17
notgetleft's Avatar
Originally Posted by Bob Cosby
If you're referring to a comparison between an LS1 F-body and an LS2 GTO (don't know of any other "lesser" car), then I'll agree they are close. But that's not a real good comparison, as they are two different motors in two different cars. What I was asking is how does and LS1 (the motor) run better than an LS2 (the motor)? The only performance vehicle that both motors have been in (in the US) are the GTO and the Vette. LS2 GTOs are measurably quicker than LS1 GTOs. Ditto the Vette.
First, I don't believe in "factory freaks". Freak drivers, freak tracks, freak weather conditions, all those freaks combining on freak days....sure. Factory freaks? Nope.
Bob, i know you have years of racing experience, so i have no idea why you'd say this. My car does not have much done to it, i ran my first 12.9 @ 110 when i just had the high flow cats and MAF pipe, still on the stock tune. The pass afterwards i didn't get as good a launch and ran a 13.0 @ 110 with an LS2 A4 GTO with just a cat back that ran 13.6 @ 106.
Maybe i'm just an incredible driver. Or then again, i can look at what happened at a local GTO dyno day...http://www.ls1gto.com/forums/showthread.php?t=74582
I accidentally swapped my HP/TQ numbers on the board, but note that i put my the same RWHP as 2 of the LS2 cars, and they both had at least cat backs and CAIs, i think one was an A4 the other M6. The only LS1s that made more power had at least cams in them. The 2 LS1 cars immediately above and below me (and some others) had LT headers and other mods, yet i still put down more RWHP. btw, i'm aware the numbers seem low, but the important thing is, it was the same dyno, same day with the same correction factors.
Same day, same conditions, my car simply made way more HP then it had any right too. And its track times back it up. I'd love to believe i'm just an incredible driver, and jesus raised teh barometric pressure in my stock air filter box to make it put down the numbers it does, but let's be realistic.
What makes a freak? I dunno, maybe i lucked into a thin pair f head gaskets, intake and exhaust manifolds that lined up perfect with the head ports, perfectly matched rocker ratios, perfectly fitting/sealing pistons, some nice loose bearings, maybe my tranny and rear are looser then most. Beats me. But you've been around race tracks enough to know that 'stock' class racers using 'stock' parts can make a lot more power then you'd expect because of painstaking detail in matching things up when they assemble their engines. Looking for exactly the kind of matching parts i mentioned above in stacks of 'stock' take out. Or are you going to tell me you've never met anyone who mic'd 50 stock mustang 5.0 cams looking for the one with the best numbers in the factory tolerances?
Finally, TQ management is specific to a year of car, and cannot be used to justify that an "LS1 engines run better than LS2 engines".
Yeah, no ****. And we're 'specifically' talking about 04 vs. 05/06 GTOs in this thread. And it's a fact that the 05/06 cars have much more invasive TQ management then the 04s, especially on the M6, which the 04 has none but the 05/06 does.
Ok, I'll take your word for all of that. Does that explain how/why an LS1 engine runs better than an LS2?
I guess I'll have to disagree, and if given the chance, I'd gladly take an LS2 over an LS1 - everything else being equal.
Fair enough. The LS2 certainly has more potential but stock for stock, it's not 50hp faster. List below is from ls1gto. There's 5mph difference between the fastest mph LS2 and slowest mph LS1s, more like 3mph on average (108 to 105). True, different tracks, drivers, conditions, etc, but i think the data is pretty clear.
LS2 Stock Classes:
2) NYTIGER 12.920 @ 109.40 MPH
3) Boilermaker GTO 12.9299 @ 106.89 MPH
4) 05torridred60 12.971 @ 108 MPH - SAP mufflers
5) jumbojet 12.974 @ 108.08 MPH
6) BlackSheep 12.98 @ 108 MPH
7) GTOboss 13.007 @ 108.52mph
8) KYGTO 13.035 @ 108.96 MPH
9) Judgethis05 13.036 @ 108.72
10) hookmechanic 13.074 @ 106.76 MPH
11) SLoW SHO 13.082 @ 108.15
12) SloNlo 13.086 @ 108.75 MPH
13) Aerobirdmotorsports 13.098@106.91
14) TheCamel 13.112 @ 108.49 MPH
15) BadGTO 13.14 @ 104.99 MPH
LS1 Stock class:
1) Nutiger 13.025 @ 108.31
2) H82BSLOGTO 13.09 @ 105.00 MPH
3) ls1gto 13.10 @ 107.3 MPH
4) TRU GTO 13.136 @ 105.76 MPH
5) GTwhoa 13.15 @ 105.35 MPH
6) nutiger 13.245 @ 104.86 MPH
7) GTONEWB 13.248 105.99 MPH
8) slammin86 13.27 @ 105.46 MPH
9) nikivee 13.3 @ 104.00 MPH
10) 1meangoat 13.307 @ 104.61 MPH
11) Nmbr1GMfan 13.390 @ 104.54 MPH
12) win98nogood 13.393 @ 105.10 MPH
Old Mar 18, 2008 | 08:59 PM
  #18
Bob Cosby's Avatar
Edited to tone down my response.
I don't believe in "factory freaks" because of my racing experience, not in spite of it. I've seen a bone stock 98 Cobra run 107 mph. Bone stock - down to the tires and air filter and factory oil. Think about that for a sec. There was a good reason for it. Was it a factory freak?
Were you on a load-bearing dyno? Was everybody's engine cool? Was anybody's? Regardless, that post on LS1GTO.com is a good example of why the dyno should be used for what it was intended to be used for: a tuning tool. I'll agree that some cars run better than others, but I would suggest that the actual power difference is along the lines of ~3%. Certainly not enough for a stock LS1 to make the same 400 HP as a stock LS2.
And it sounds like you a very good driver. I'll defer to my earlier statement about freak air, freak track, freak drivers, etc.
Yes, Factory Stock and NHRA stock eliminator racers absolutely "shop" stock parts. Some are better than others. But they are typically looking for 4 or 5 HP worth of difference at that point. Literally.
I am not argueing that the LS1 GTO is capable of running within a couple of tenths of the LS2 GTO. That is more a function of the car (as you point out) than the engine. My point was related solely to the engine. The LS2 engine is still more powerful, and IMHO, superior to the LS1 in virtually every respect. This was central reason for my entrance into this thread.
Bob
Old Mar 19, 2008 | 12:23 AM
  #19
boxerperson's Avatar
Hm. And here I figured he meant that the reliability of the LS1's was better than for the LS2's....
Old Mar 19, 2008 | 06:16 AM
  #20
Bob Cosby's Avatar
Maybe he did. If so, I have not researched that enough to make any educated comments on it.
Old Mar 19, 2008 | 08:35 AM
  #21
Chrisz24's Avatar
Originally Posted by christianjax
I can see what the OP is saying. I will be pissed if I fork over $35-$40k for the new convertible with whatever V8 is available, then the next year they bump the base V8 by 50hp. (Like they did to the GTO) AND the SSR.
Why?
I'm glad I have the LS1, I didnt want the Ls2 since it was new and I knew the LS1 had a history since it was already out 9 years when I bought my car!
As it turns out, the LS2 was only produced 3 years then droped..... why? Either way, I'm glad with my decision and dont look back wanting more or a different engine.
Old Mar 19, 2008 | 11:56 AM
  #22
christianjax's Avatar
Originally Posted by Chrisz24
Why?
This isn't just about the LS1 vs LS2, it's about spending that much money on a car and the following year it get's "one upped" making you feel like you should have waited. When I buy the first convertible I can get with the biggest engine available, I reasonably expect it to remain unchanged (power wise) for about 3 years, so when the power bump comes I'm about ready to trade in. Image the poor slobs that bought a 1985 Grand National. Then the 86 and 87's came out with intercoolers and a LOT more power. Keep in mind that 84 was the first year for those. But the 84's and 85's weren't anything special. But the 86's and especially the 87's acheived cult status.
Old Mar 19, 2008 | 01:37 PM
  #23
guionM's Avatar
And again, I argue that if one buying a new car is worried about being one upped on horsepower a year or two or three in the future probally shouldn't be buying a new car in the first place because they are buying for the wrong reason. They should buy a used car and change engines as frequently as their hearts content.
The first and key reasons for buying a new car should always be because it fits your needs and you want that car. If it's mead well and offers a great value, you aren't going to give a hoot if it gets a 30 or 50 horsepower jump the next year.
Also, no car maker is ever going to publically say if they are going to up horsepower the following year. In fact, they are likely to keep it secret till the last possible moment. Chrysler 5.7 Hemis are going up to 370hp and 400 lbs/ft of torque this fall. How would that affect the 2007 Charger R/T buyer if Chrysler had let that out, say, a year and a half ago??
Also, horsepower outputs are state secrets nowadays, especially in performance cars. GM is in no way, shape, form, or fashion gonna let known (if at all within their power) what Camaro's horsepower is going to be until it's too late for the competition to react. Neither is Ford, or Chrysler, or Toyota, or BMW.
So, again, don't worry about being one upped the following year.
If you want the car, buy the car.
Old Mar 19, 2008 | 02:07 PM
  #24
I agree with you on many levels. I understand that GM isn't going to announce that the 2011 Camaro will have X more power than the 2010. But if I pay upwards of 40 Grand for the new Camaro convertible and the V8 of the same level the FOLLOWING year is throwing down 50 more horsepower I'm going to be pi$$ed. Period. I understand the Top Dog is another deal all together. I'm talking about equally equipted cars. Say 2010 Z28 to 2011 Z28. Now I don't feel that the 2010 Camaro Convertible will be "UNDER POWERED" like say the first SSR's were. So it won't sting as much. It's not like they are going to put the L76 361hp engine in the first year and then FINALLY drop in the LS3 with 430 hp in the next year. But THAT would pi$$ me off tremendously if they did.
Old Mar 19, 2008 | 02:16 PM
  #25
JakeRobb's Avatar
Super Moderator
Personally, I think waiting to buy a new Camaro with a Gen5 engine might be exactly what I'll do. I won't be in a financial situation to buy a new car a year from now anyway, so I might as well wait a whole year and see what new options pop up.
If, at that point, they're still not on the Gen5, then maybe I can pick up a year-old '10 model to hold me over.
Old Mar 20, 2008 | 10:31 PM
  #26
MauriSSio's Avatar
i think the Z28 will have the 361HP engine, then i think they'll introduce the 405HP version the next year or so as an SS. Just like the G8, kinda makes sense since its built on the same platform that they will have the same engines available right?
Old Mar 21, 2008 | 12:03 AM
  #27
99SilverSS's Avatar
I think your both in agreement but from different points of view. You’re saying that car companies keep hp numbers secret because of competition and because of a potential sales dips in the current model. I think he is saying that should he be one of those unfortunate to have purchased a vehicle only to be one upped the next year by a different engine or just more power that he would be annoyed. I can't blame him for that.
I wouldn't loose any sleep if I bought a 2007 Explorer or Impala and I found out later that the 2008 models now have more power. However, I would be quite annoyed to be say the proud owner of a 1997 LT1 Z28 only to be upped by the 1998 LS1 F-bodies and their “advertised” 20hp increase in power... Not that I would know anything about this first hand. ...
Old Mar 21, 2008 | 05:40 AM
  #28
The difference is that the 1997 was the 4th year of the LT1 Camaro. So the 98 LS1 upgrade was on time. So those that bought the 93 to be the first with the 4th gen weren't screwed the very next year. (unlike first year GTO and SSR owners). I want whatever V8 they decide to stick in the Camaro to be there for at least 3 years before a major upgrade in power. (except of course for the top dog model which we already know is coming) That puts forth a challenge to GM to forcast BEFORE they release the 5th Gen what the competition will be and plan accordingly. (And I don't think 361hp will cut it.) And not wing it on the fly the next year. Wishful thinking I know.
Old Mar 21, 2008 | 12:24 PM
  #29
99SilverSS's Avatar
The only thing I can say about this is to keep a close eye out here on this site. I think we will know much more about GM's plans for engine or power far more in advance than I did w/o the net in '97.... once the Camaro hits the streets of course.
I don't think there is any protection from GM placing the new and better SBC in the Camaro when it's available. I think it's safe to say the base engine in the Vette is very likely to be the one in the Camaro either the same year or the next. Note that all recent changes in Vette engine be it LT1, LS1, LS2 and now LS3 have trickled down to other performance vehicles at GM soon after. It's just timing more than GM saying the LT1 will be used for the first 4 years of F-body production and then the LS1 takes over. GM wasn't going to continue LT1 production just for the F-body.
I do think the Camaro will be safe from any engine upgrade from say the LS3 for a few years. Timing for the C7 is around 2011 and if GM follows the intro of the C5 and C6 with a new base engine for a new gen. that will give the Camaro 3 years of LS3 time before moving up to the next Vette base engine.
Old Mar 21, 2008 | 06:56 PM
  #30
8Banger's Avatar
I've had both. Give me the LS2 ANY DAY!!
