LS7 Automatic
Old Jun 21, 2009 | 08:29 AM
  #16
jay_lt4's Avatar
Originally Posted by JakeRobb
Cool. So you pulled out the L99 and swapped in a 415ci LS3? Or did you have the L99 converted and modified?
i had the 415ci LS3 all built and ready to drop in even before my car came in.
Old Jun 21, 2009 | 08:46 AM
  #17
JakeRobb's Avatar
Super Moderator
Nice! How much power are you making?
Old Jun 21, 2009 | 02:17 PM
  #18
rpepka's Avatar
When GM decided to put a supercharger on an LS engine, they considered using both the LS3 and LS7 as a starting point. They ended up going with the LS3 because its thicker cylinder walls are better suited to the increased cylinder pressure. As a result, both the LSA (CTS-V) and LS9 (Corvette ZR1) are based on the LS3 (they use the exact same block!).
The L99 is just an LS3 with VVT, DOD, and a different cam profile -- the block and heads are identical. I've seen 505 hp at the rear wheels from an LS3 with a big cam and longtube headers. That translates to roughly 575hp at the flywheel.
With a VVT-enabled L99, you should be able to achieve similar peak horsepower while also maintaining a broader torque curve than any non-VVT engine.
Personally, I think the L99 is the most interesting engine GM has ever made from a modification and power potential standpoint.
If it were me, I'd stick with your L99 and see how far you can get with it. If you still want the big cubes, get it bored and stroked to 418ci (that's 97.9% the displacement of the LS7). You'll still have thicker cylinder walls than an LS7, making it still the better platform for forced induction.
You can do all of that, including the supercharger, and you'll still probably have spent less than you would on a bone-stock crate LS7.
Then you can use that money to beef up the rest of the drivetrain. You're going to need it!
Ok then could you be specific:
American Racing headers with Cats $1800
Cam? ( Not to lumpy please)?
Bore and stroke Kit? From who?
Etc......
Paint me a road map, please.
Old Jun 21, 2009 | 10:34 PM
  #19
JakeRobb's Avatar
Super Moderator
Etc......
I'll let jay_lt4 paint you the map, since he's actually been down that road.
Old Jun 26, 2009 | 12:20 PM
  #20
XcYZ's Avatar
Sorry I dont know what a wet sump is.
Hmmmm, I see.
Is anyone building headers for a 5th Gen/LS7 swap?
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
