do wires make a difference
Old Jun 12, 2013 | 12:39 PM
evilchevy's Avatar
I have been looking around to see if a coil and wire change will get me more hp and even more mpg and i have seen a lot of different thing i have seen wires that are the same size as stock or thicker, that they come in all different colors but i have headers so i know it will be getting hotter by the headers then what stock is, and for coils i hear the stock works just fine is that true is there does anyone make an aftermarket coil that works better ???
Old Jul 13, 2013 | 11:20 AM
v6sonoma's Avatar
Re: do wires make a difference
From what I have seen there is little to nothing to gain over the stock LS3 stuff.
Old Jul 14, 2013 | 08:52 AM
parkers Z28's Avatar
They will make a difference if your engines has 700hp where you need a hotter spark. I'm not sure what is the best way to get more hp out of the 5th gen. look into getting a Cold air intake and better flowing exhaust
Old Sep 28, 2013 | 01:02 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs down Re: do wires make a difference
Sir, you have a 48K coil with a maximum 10" wire going straight to the spark plug, even with a high resistance wire, YOU CAN POWER UP FRANKENSTIEN WITH IT!!!
JMHO
SteveC
Old Oct 28, 2013 | 08:05 PM
Mr99SS's Avatar
msd wires are cheap and work cant hurt ... especially with headers
Old Mar 1, 2015 | 07:25 PM
You IP address indicates you are posting from Pakistan. Are there many 5th Gen Camaros there?
IP = Pakistan Kamalia Usf Dslam Central
Old Mar 26, 2015 | 04:09 PM
ZeeS7o7's Avatar
Camaro or Camel?
Old Jun 13, 2016 | 06:21 PM
LS1Nat's Avatar
Originally Posted by ZeeS7o7
Camaro or Camel?
Old Apr 21, 2018 | 07:49 PM
BraydenMurphy33's Avatar
In a mostly stock engine you'll notice zero difference from swapping out the wires. Put your money into other mods if you want a performance increase. Nice bright colored wires look nicer though.
Jan 23, 2015 01:13 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
