Cold Air Induction for the 2010 V8 with No Oil?
Old Mar 20, 2010 | 11:19 AM
Breakwind's Avatar
Dealer advises to watch out for CAI aftermarkets due to oil from the filter being sucked in and effecting sensors.
Any advice for a good Camaro 2010 CAI kit for the V8 that only uses a dry filter system?
Old Mar 20, 2010 | 12:58 PM
JasonD's Avatar
Admin Emeritus
What the dealer says is partially true. Most (if not all) oil-based air filters suggest that you only put a very thin coat of oil on the filter. As a lot of people think "if a little is good, a lot is better" and that is not always the case. I am sure that if you completely soak the filter...sure, some oil will make it to the sensor but you would really have to overdo it, IMO.
I don't know of a good dry filter system off the top of my head, though.
Old Mar 20, 2010 | 02:33 PM
powerhog's Avatar
Dry CAI filter
I put a dry one on from roto-fab, comes with oil or dry, dry is $12.00 extra and is washable, do not have any issues yet and was easy to install, no codes.
Old Mar 20, 2010 | 04:18 PM
wbt's Avatar
wbt
As Jason mentioned the oil based filters really require a hearty "over-do-it" application for any to pass through and affect the MAF, etc...
In general the oil coated filters will produce more power while the non-oil are slightly easier to maintain. If you follow the directions from the K&N recharge kit it is hard to mess up on the oil filers IMO. Hope that helps.
Old Mar 22, 2010 | 09:50 AM
2010_5thgen's Avatar
i went with airiad.works great. no problems.
Old Mar 22, 2010 | 07:08 PM
Breakwind's Avatar
Thumbs up Thanks
Thanks group...appreciate the info!
Old Apr 20, 2010 | 08:32 PM
amp man's Avatar
Rc2
I went with RC2 cold air intake system,Has dry filter that just uses
compressed air to clean.Performs great!
Old Sep 22, 2011 | 04:38 PM
joe603's Avatar
Re: Cold Air Induction for the 2010 V8 with No Oil?
+1 for R2C!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
ReznorZ28
Aug 27, 2002 03:53 PM
BM93Z
Aug 22, 2002 02:45 PM
