Bye-Bye to GM's V-8s
The main problem I see when you compare V6 to V8 in a car, is the transmission.
I also read about it once on here.
Basically the transmission is setup for the v8, and the V6 with those gear ratios is just pure weak, even if you change rear gears, it doesn't make up for it. Maybe we'll see better transmissions design specifically for V6 engines.
In something like the Camaro, The V6 doesn't make that big of a difference in terms of gas mileage. My v6 camaro gets about 35 mpg or so and i've seen plenty of Z28s that get about 30. and those are 12 year old cars. If those camaros had todays technology then they would probably be getting better gas mileage. And like someone else said the V8s will never leave the truck. you think Toyota is gonna take their 5.7L out of the tundra? hell no. and as long as they don't give it up neither will GM or Ford or Dodge or Nissan cause all of them won't be able to compete if they did.
Oh and they need to drop the inline 6 before they drop the V8 if they're worried about gas. especially in SUVs inline 6s are horrible on gas, worse than the V8s. Inline 6s are good for midrange power but that's about it
You are correct, my mistake.
To all those who say a 6 cyl won't cut it because of a lack of torque, tell that to the guy driving this:
The number of cylinders does not make the torque, displacement does. Give me a 6 liter straight-6 and I'll show you some torque.
long ago, i talked to Scott about an "import beater" built from readily GM Parts.
put a V6 (i think the year 2000 V6 had ~225HP?) and a T56 in a Cavalier with 4:10 gears.
i think that would be a ROCKET. the V6 would make enough HP/TQ for the light weight of a Cavalier,
and the 4:10 gears would ensure the V6 could dig out of the hole, and keep moving on top end to a high MPH
and a M6, well, is just the funnest transmission there is.
i think that would put the import/tuner/ricer world on it's ear.
a light weight RWD car with world class potential
and the aftermarket would go crazy.
who would be the first to twin turbo one?
the inline 6 cylinder Cummins Turbo Diesel in your average dodge pick'em'up makes 325/610 stock,
and with a intake, exhaust, programmer & nitrous, will do 500/1000 all day long.
T56 6-speed, turbo 4.0L V6, RWD, sedan: http://en.wikipedia.org/wiki/Ford_Falcon_XR6_Turbo
Of course this one's over 380hp and a bit larger...
2007 Pontiac Solstice GXP - Road Tests
BY DAVE VANDERWERP, PHOTOGRAPHY BY MORGAN J. SEGAL
October 2006 C&D
"This 2007 Solstice, and also the mechanically similar Saturn Sky Red Line, packs a punch of 260 horsepower and 260 pound-feet of torque from a direct-injection turbocharged and intercooled 2.0-liter version of GM’s four-cylinder Ecotec. Yes, the stodgy General is introducing its first gasoline direct-injection turbo at the same time as BMW. Shocked"?
October 2006 C&D
And the HHR SS makes four unless I missed some news. But didn't the FWDs get a slight de-tune (5-15 HP)?
The original small block lasted how many years?
So they dropped the luxury DOHC V8, that does not mean they won't invest something into the Northstar maybe Direct Injection, Variable cams, etc.
I think they need to fix how they spend their money. For one, they need to pay some lobbyists to get Universal Health care passed. There is about 1800 per car right there. You can pay your execs millions of dollars each, pay me a few mill and I will go bug the hell out of those bastards. Drop the huge ad campaigns and go for something more unique. Then, they need to lobby the government to sponsor research into inexpensive lighter and stronger materials. Research ways to make new materials like composites or those new "foam" metals less expensive.
A 1983 Ford Escort wagon would get 54 MPG. Look at the weight of that car VS a 2008 Ford Focus. There's your problem.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Z284ever
22
Nov 5, 2003 02:13 PM
Ted 99 TA WS6 Conv
10
Jul 30, 2003 06:41 AM
