Any 5th gen free mods?
Re: Any 5th gen free mods?
Except for the #5 and #20 fuse-pull for the SS, to reset the fuel map if you haven't done so already.
If you didn't know about this one...cheap/regular gas used when the dealer fills up the car before delivery causes the car to adjust the fuel map. The programming in the ECM is only uni-directional. Once the fuel map has been adjusted for cheap gas, it can't reset if the octane goes back up. I burned through the first tank of 'dealer gas', filled up with premium, and then reset the ECM about 50 miles later. Nice difference!
If you disconnect the Wiring Harness from the Injectors on each side, you can carefully tuck the Harness behind each Injector. Then reconnect each clip & the wiring's well hidden.
After you're done, 1 more ugly thing disappears out from plain view on the top of your engine.
one free mod ! remove the water bottle which resembles a dead goose , it gets more air flowing and the goose weights 9 lbs according to Hot Rod mag, well thats free if you can live with out washer fluid if not you can spend afew $$ and replace it check out the thread here on Cz28 for more (and add the air scoop also not free )
https://www.camaroz28.com/forums/sho...d.php?t=816973
black out your tail light bezels is a pretty cheap mod
mucker, where did you get that air scoop at? does it help feed air to the intake better? i disconnected my washer fluid hoses anyways because of my hood, so i may take the whole washer fluid bottle out.
got it from adm all the info is here
with out the bottle I felt a difference and with the scoop it was def better, its nto going to change the world but more air is good more air better directed is better I was happy with the mod
you felt the car got better air flow by just getting rid of the washer bottle? hmmmm. maybe ill pull mine out tonight.
is this it right here? http://www.admperformance.com/produc...66&product=239
