ZL-1 engine for camaro?
Old Oct 21, 2008 | 11:49 PM
mike mlodecki's Avatar
I saw on motor trend that the camaro might have the ZL-1 engine in it, the 376 cu pushing 505 hp @6300 rpm and 470 torque @4800 rpm, it also says its a 11.4 sec 1/4 mile @130.5 mph weighing in at 3600lbs. now idk if this is true can nebody help me out here. i mean this is a brand new camaro they should at least have to put an engine in here to take the shelby gt500.
Old Oct 22, 2008 | 01:30 AM
IPrice's Avatar
I ain't a rocket scientist...but Id have to raise the ol' on that unless I saw it in writing.
..and we all know how many times things change from writing to production model.
Besides, those bafoons on Motor Trend are silly. Why would GM put a 7 year old motor in car like the Z?? Id much rather predict the LS7 or something new...I dunno
My $.02,
Ivan
Old Oct 22, 2008 | 02:36 AM
DAKMOR's Avatar
can we keep all speculation to a specific forum please?
Old Oct 22, 2008 | 04:47 AM
guionM's Avatar
Do the initials "BS" mean anything to ya, Mike?
Old Oct 22, 2008 | 07:13 AM
Bearcat Steve's Avatar
3600 pounds...
505 hp (at the crank)...
11.4 in the 1/4...
Obviously not with stock tires.
Even with stickies, co-efficient of drag and parasitic loss of IRS would not allow that to happen.
Old Oct 22, 2008 | 07:20 AM
i know but its jus nice to maybe think it will happen even tho i also doubt it
Old Oct 22, 2008 | 07:43 AM
JasonD's Avatar
Admin Emeritus
Mike, did you mean ZR-1?
Old Oct 22, 2008 | 09:45 AM
IPrice's Avatar
That might make a little more sense.
-Ivan
Old Oct 22, 2008 | 09:57 AM
My Red 93Z-28's Avatar
Maybe he meant Z06...the hp/tq he posted are for the LS7, but the displacement is the same as the ZR-1?
On a side note, why is there such a huge drop off between the models? The ZR-1 with 638 hp and is the fastest Corvette, and then you have the ZR-2...which I guess is the fastest S-10?
Old Oct 22, 2008 | 10:03 AM
no i actually saw on motor trend that they used the zl-1 idk im jus kinda bummed that this car isnt gonna get a lot fo power in it for a brand new sports car
Old Oct 22, 2008 | 10:10 AM
Z284ever's Avatar
3600 pounds? Not a chance......
Old Oct 22, 2008 | 10:53 AM
jg95z28's Avatar
GMPP did reintroduce the ZL-1 as a special edition crate motor a short time back (last couple years?) however that was an all-aluminum block big block at 454 cid.
So the ZL-1 in a Camaro? No way. I serious doubt GM would put the supercharged LS9 in the Camaro as well as there's no way they'd put their $116k super Corvette ZR-1 motor in anything but the ZR-1. The little sister LSA could be a possibility, but then we know that pushes 556 hp in the Caddy, but 505 hp could be a detuned number for Camaro. However, 505hp sounds like the LS7 in the Z06, but that's 505 hp with the dry sump set-up and rear mounted transmission. And 3600-lbs? As Charlie said, "not a chance."
Seriously though, why not simply use the hotcam version of the LS3 which GMPP already sells as a crate motor and which puts out 480 hp? I for one would be perfectly content with a Z/28 with just under 500 hp and some weight savings off the SS.
Old Oct 22, 2008 | 11:17 AM
vonmoldy's Avatar
Wasn't the ZL-1 on the first gen cars a 427? Why the heck would they put a crate motor which is less advanced in a modern car?
Old Oct 22, 2008 | 11:21 AM
jg95z28's Avatar
Yes. 1969 only, and only 69 were built.
Old Oct 22, 2008 | 11:30 AM
zq8colorado04's Avatar
My dad just bought the "Anniversary 427 ZL-1" engine that they just came out with...it's supposed to be at the house on Friday or Monday...
oh yeah, only 427 of the anniversary ones are going to be built....
