Camaro bloat article on jalopnik
Old Jan 28, 2009 | 02:58 PM
John_H's Avatar
Just saw it and I thought I'd share it.
http://jalopnik.com/5140813/model-bl...37-model-years
Old Jan 28, 2009 | 03:27 PM
yellow_99_gt's Avatar
If they compared a 67 SS with the top of the line motor to a 2010 SS it would be more like 250lbs, not 800+.
Old Jan 28, 2009 | 03:53 PM
CLEAN's Avatar
Not sure I agree w/ their chart. How did the 1992 model gain weight over the '91? and why is the '02 100 lbs heavier than an '01?
Old Jan 28, 2009 | 04:09 PM
JakeRobb's Avatar
Super Moderator
My guess, in both cases, is that the figures are averages weighted by the number sold, and that in '92 and '02, anniversary editions caused convertibles to sell in larger numbers than usual.
Old Jan 28, 2009 | 10:54 PM
guionM's Avatar
Take these weights for whatever you want.
The curb weight for a 6 cylinder 1967 Chevrolet Camaro was listed by GENERAL MOTORS as 2910 pounds.
All figures below are from General motors regarding the '67 Camaro:
3,070 pounds for the 8-cylinder coupe, 3,165 pounds for the 6-cylinder convertible, and 3,325 for the 8-cylinder convertible.
Add 21 pounds for power windows
20 pounds for the folding rear seat
86 pounds for air conditioning
9 pounds for power brakes
23 pounds for front disc brakes
10 pounds for the 250-cid 6-cylinder engine
39 pounds for the 327-cid V-8 engine
72 pounds for the 350-cid V-8 engine
258 pounds for the 396-cid V-8 engine
7 pounds for the four speed manual transmission
14 pounds for the Powerglide
56 pounds for the Turbo Hydra-Matic
38 pounds for dual exhaust
29 pounds for power steering
15 pounds for heavy duty battery
8 pounds for an AM radio
9 pounds for an AM-FM radio
and 17 pounds for the Rally Sport package.
2nd gens ranged from a low of 3313 pounds (1971 6 cylinder) to 3828 for the final 74 Z28s, to approx 3612 pounds for a base 1980 Z28 (Camaro underwent weight reduction, including lighter 5 mph bumpers)
1992, 3rd gen Camaro weights, from GM:
Shipping Curb
Weight Weight
Camaro Coupe 3025 3105
Convertible 3142 3220
Z/28 Coupe 3194 3273
Convertible 3298 3377
Weight Differentials
AC3 Power Seat 7.9
AM9 Fold Down Rear Seat -3.5
AU3 Power Locks 3.1
A31 Power Windows 3.9
B84 Side Molding 1.3
CC1 T-Tops 29.5
C49 Rear defogger 0.9
C60 Air conditioning 41.7 with V-6
C60 Air Conditioning 42.6 with 305 TPI & 700R4
C60 Air conditioning 46.3 with 305 TBI & 700R4
C60 Air Conditioning 42.7 with L98
DE1 Back window Shade 18.5
D34 Vanity Mirror 0.4
DG7 Electric Side Mirrors 1.3
F41 Suspension -6.6
J65 4-wheel disc brakes 2.6 (Z/28 w/L98 only)
K34 Cruise control 5.3
MD8 Automatic Trans 101.9 (with 305 & 350)
N10 Dual exhaust 12.8
T96 Fog Lamps 4.4
UA1 H.D. Battery 0.4
UL5 Radio delete -5.7
U75 Power Antenna 2.6
This is a cut and paste of weights of the 1997 Camaro from media.GM:
Curb Weights 1500 kg (3310 lb.) - Coupe (w/3.8L V6)
1560 kg (3440 lb.) - Z28 Coupe (w5.7L V8)
1570 kg (3455 lb.) - Convertible (w/3.8L V6)
1630 kg (3590 lb.) - Z28 Convertible (w/5.7L V8)
The 2002 Camaro...same source
Coupes Z28 Convertible
Curb Weights 1510 kg. 1570 kg.
(3325 lb.) (3455 lb.)
w/ 3.8L V6 w/ 3.8L V6
1545 kg. 1605 kg.
(3405 lb.) (3535 lb.)
w/ 5.7L V8 (Z28) w/ 5.7L V8 (Z28)
The article is way off the mark on the 1st gen Camaros.
On the 2nd gen, they have a very big generalization. 2nd gen weights veried greatly due to the addition of 5mph bumpers and reinforced structures to support them, as well as additional pollution equptment gained and the loss of dual exhausts, the significantly lighter 305 V8 and THM200 transmission, and the revised bumper & weight loss in later years.
The 3rd gen's 3300 pounds is pretty close.
The 4th gen lost about 40 pounds with the LS1 over the LT1, but also is close.
Later years had less variation of options and equptment, so there isn't as great of a range of weight.
FWIW, an SS 396 Camaro could weigh all the way up to 3800 pounds.... a '69 Z28 could reach 3760.
.... and I'm not talking the convertibles either.
Old Jan 29, 2009 | 12:30 AM
IZ28's Avatar
Couldn't they find a picture of a nicer Third Gen?
Alot of those numbers are obviously off, and they're just going by the lightest models not the heaviest.
Old Jan 29, 2009 | 03:12 PM
jg95z28's Avatar
What a load of crap!
Old Jan 29, 2009 | 07:51 PM
99SilverSS's Avatar
Will someone please send them some better pics of a 1st, 2nd and 3rd Gen Camaro. Did they just drive around looking for a Camaro and found those? Each picture looks vintage.
I think they will find and many of us already know that many production cars get larger and heavier at each generation change. There are a few exceptions, Corvette.
We've beat the weight issue on the 5th Gen Camaro to death many times over. In order to get a 5th Gen Camaro it needed a RWD platform that was ready, available, cheap enough to keep the cars' overall cost down and strong enough to compete in todays market with 420+ Hp and Tq on tap. So Zeta with its sedan roots was chosen and the rest is history. The 5th Gen Camaro is a slight departure from the prior 4 generations and has to meet all of todays standards. So while I don't like the bloat in weight I understand it.
Old Feb 1, 2009 | 03:43 AM
teal98's Avatar
Why don't they just take the '84 4cyl chassis and hook up an LS3? That would only be around 3300 pounds with 425hp.
I'm sure the drive line and chassis and tires and brakes could handle the extra 335hp just fine.
No strengthening is necessary, because I heard once that someone put a turbo V8 in one of these. No one needs A/C, because you can just roll down the windows and turn up the vent if it's too hot inside.
kidding
NewsBot
Dec 30, 2014 09:40 AM
NewsBot
Dec 24, 2014 11:05 PM
NewsBot
Dec 21, 2014 06:55 PM
cmsmith
Dec 10, 2014 08:57 PM
NewsBot
Nov 25, 2014 11:20 AM
