3rd brake lite wiring
Old 08-01-2011, 01:10 PM
bea yeller's Avatar
Smile 3rd brake lite wiring
I want to add a flasher to the third brake lite on my 2010 camaro 1ss/rs- can anyone tell me where is the wiring to the 3rd brake lite unit hidden and is it a single wire or a two wire system? I do not want to tear out the rear package tray or the interior if I can help it. Thanks for any information. KL
bea yeller is offline
Old 08-11-2011, 06:52 PM
sniperSS's Avatar
Re: 3rd brake lite wiring
The wiring harness connection is behind the right panel under the small side window. Lower the seat, grab that plastic panel and pull evenly. When you get in there, the connection plugs into the main harness at the right rear as you face the panel. You will see the third lite wiring go off to under the rear window shelf.
sniperSS is offline
Old 08-14-2011, 07:36 PM
Admin Emeritus
JasonD's Avatar
Nice info! Bea Yeller...how did you progress go?
JasonD is offline
WildRidez
02-23-2015 07:24 PM
Moshbmx1
02-17-2015 10:51 AM
07-04-2005 05:00 PM
Quick Reply: 3rd brake lite wiring
