Trans Am with zr1's 17x11 and 36mm offset?
Old 04-01-2005, 11:53 AM
Kurt Crosbie's Avatar
How much are the wheels going to stick out in the back?
Kurt Crosbie is offline
Old 04-01-2005, 12:01 PM
Re: Trans Am with zr1's 17x11 and 36mm offset?
They will move out exactly 0.55" further than these:
http://cjcfo.fbody.com/members/injun...C/RrView01.jpg
Injuneer is online now
Old 04-01-2005, 12:02 PM
So if i went over a bump, my rear wheels would hit the fenders and damage them?
Old 04-01-2005, 12:06 PM
You would very likely need to "roll" the sharp inner edge of the fender opening up a bit. Otherwise, the edge of the lip would rub on the outside edge of the tires. Even with the 50mm offset, I had one side rub on the tire on really hard shifts.
Old 04-01-2005, 12:51 PM
oh, like those mustang wheels i put on my probe that one time...
so, i can roll that sharp lip up by myself? what tools do ineed?
Old 04-07-2005, 09:26 PM
fireman's Avatar
I ran 36mm offset 17x11 chrome ZR1s on the rear of my Formula for over year without a problem. Went to the track often too. Pulled countless 2.0 60's and never did any visible damage to the tires. Had a nice wide lip on those 36mm ZR1s, looked awesome.
fireman is offline
Old 04-07-2005, 11:06 PM
ok, can i see pictures?
Old 04-08-2005, 09:18 PM
fireman's Avatar
I got some at home, try and get 'em up tomorrow.
fireman is offline
Old 04-08-2005, 11:33 PM
that would definitly be awesome.
Old 04-10-2005, 07:48 AM
lons94z's Avatar
Again depends on what has been done to the car.
PHR, LCA's, spring rate, bar size. Lowered? How much?
94bird used the 36mm offset wheels at all corners with no problems.
lons94z is offline
Old 04-11-2005, 10:57 PM
still waiting for some pictures.
Old 04-12-2005, 09:18 AM
A quick "search" on "36mm offset" would have found you this thread.
http://web.camaross.com/forums/showthread.php?t=288246
Old 04-12-2005, 10:24 AM
thanks
Old 04-14-2005, 12:38 PM
I like Injuneer's setup better than the black one in the link. Who's with me.
btw injuneer... Sorry about that situation with the fuel rails.
Old 04-16-2005, 09:08 AM
90 Z28SS's Avatar
I had black 36 mm offset 17x11 ZR1 wheels . Pics are in my sig . I wouldnt EVER do that again . After shredding up the sidewall on one tire , I rolled the inner lip and still had problems . On the highway , areas where theres a dip the tires will almost always kiss the top of the fender lip and hard cornering they will as well . Maybe stock ride height you would have better luck , I dunno . a friend of mine has 50mm 17x11's on his TA and it just looks so much better and there are no issues at all .
90 Z28SS is offline
bowtieboy95
07-01-2015 06:49 AM
LD Kirk
04-30-2015 08:54 AM
sloppytot
02-25-2015 08:30 PM
Ken Cemo
Parts Wanted
01-28-2015 09:04 AM
Quick Reply: Trans Am with zr1's 17x11 and 36mm offset?
