18x10 fronts on a 4th gen
Old 03-08-2012, 10:09 AM
leftoverz28's Avatar
Anyone on here ever run 18x10s on the front of their 4th gen?
I'm trying to order wheels soon but not sure what offset to go on my fronts.
Anybody have any idea of an offset that would fit?
Any info would be much appreciated.
thanks,
Mike
leftoverz28 is offline
Old 03-08-2012, 10:15 AM
greenformula94's Avatar
Re: 18x10 fronts on a 4th gen
It works.
I have 18x9.5's on the front of mine with 275/35's
lemme check my offset for ya....
greenformula94 is offline
Old 03-08-2012, 10:21 AM
Mine are 45mm all around.
So if you are adding a half inch you should be find I have room for growth still.
Also I had 17x10.5" rims with 275's all around and drive like that for a year, they never rubbed.
So it is completely doable.
Old 03-11-2012, 02:36 PM
BandDirector Blk98ZM6's Avatar
I've run OEM C6 19x10's all the way around with a 275/30/19 tire and they fit just fine with the correct offset. I had to use 1.25" adapters since the OEM C6 19x10 has a 79mm offset, but my point is that a 10" wide rim will fit if it has the correct offset.
BandDirector Blk98ZM6 is offline
Old 05-02-2012, 08:32 AM
Thanks guys.
I'' prob end up running my rear c5 vette 10.5s on the front until i know exactly what wheels I want. Pretty sure these will fit with the correct spacer.
HOFFICER
04-06-2020 10:36 AM
07-04-2005 05:00 PM
stars1010
07-15-2002 03:51 AM
Doug Harden
11
07-14-2002 04:31 PM
Quick Reply: 18x10 fronts on a 4th gen
