95 v6 3.4 mileage problems
Old 03-07-2012, 12:38 PM
eithacos's Avatar
i picked up a v6 3.4 with a gutted cat the gas mileage is terrible (somewhere between 10-15 mpg) i took it to a muffler shop and i was told that the o2 sensor was getting a false reading because the cat was gutted is this true and what can i do to test/fix it? i get a ses light on the highway as soon as i let off the gas but for some reason he couldnt get a reading from the computer any help or ideas is much appreciated
eithacos is offline
Old 03-12-2012, 11:21 PM
Sinister-Z's Avatar
Re: 95 v6 3.4 mileage problems
Is the O2 sensor behind the cat? If not then the O2 shouldn't throw any codes. I would start with a good tune up (plugs, wires, filters) and see where your at.
Sinister-Z is offline
Old 03-13-2012, 04:27 PM
sick94's Avatar
The O2 sensor on a 3.4L is before the cat so that should not be your problem. Check plugs, wires, coils, fuel filter, egr valve, pvc valve, air filter, etc.
sick94 is offline
Old 03-18-2012, 02:28 AM
ImportKILLER's Avatar
Pre-cat: will affect MPGs
Post-cat: won't affect MPGs, simply checks cat efficiency.
o2s are cheap enough, replace it and see if it helps. Won't hurt having a fresh o2 on there.
ImportKILLER is offline
SpeedJunkee
04-23-2015 09:51 AM
HectorM52
01-30-2015 11:08 PM
Jason Short
01-19-2015 06:34 PM
12-01-2014 08:08 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: 95 v6 3.4 mileage problems
