Wheel hop hell.
Old 08-31-2014, 07:49 PM
Zee man's Avatar
Wheel hop hell.
A while back I transplanted a ls-1 into my 94 z 28. Everyything was fine at first, then a couple weeks ago it started to wheel hop if I spun the tires. It does it one wheel at a time , right wheel up, left wheel down then left wheel up right wheel down. Its pretty frikken violent.
So far I replaced the trailing arms for the 98's the bushings are in better shape. I put on new shocks. I also preloaded the trailing arm bushings with weight on the axel. no difference. The torque arm bushing looked ok when I had it off last time.
So what do I try next?
if this is in the wrong area please move it, thanks
Zee man is offline
Old 09-22-2014, 10:28 PM
Fatdog2's Avatar
Re: Wheel hop hell.
Since nobody chimed in I'm going to say drag shocks may be needed here.Hope this helps.
Fatdog2 is offline
Old 10-02-2014, 07:54 PM
FirstYrLS1Z's Avatar
Re: Wheel hop hell.
LCA bolt-in relocation brackets.
FirstYrLS1Z is offline
Old 11-12-2014, 06:02 PM
Zee man's Avatar
Re: Wheel hop hell.
I forgot all about this thread. I ended up putting some KYB gas, nonadjustable shocks on it, with a urethane torque arm mount. No more wheel hop.
Thanks to all that replied.
Zee man is offline
Old 11-19-2014, 01:12 PM
mzgp5x's Avatar
Re: Wheel hop hell.
Try a geared diff.
mzgp5x is offline
force10
08-10-2015 08:30 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
SAR2K
09-01-2002 10:49 AM
wytblur
08-05-2002 02:03 PM
Quick Reply: Wheel hop hell.
