Replacing brakes yourself
Old 11-26-2012, 04:10 PM
Snoman73's Avatar
anyone have any helpful tips/tricks for replacing the front brake pads and the rear pads in the drum on a 95 camaro? going to do it myself to save some money
Snoman73 is offline
Old 11-28-2012, 02:38 PM
markwoods99cama's Avatar
Re: Replacing brakes yourself
just watch what your doing and put it back together the same man its not all that bad just make sure u got a c clamp
markwoods99cama is offline
Old 11-29-2012, 11:20 AM
transamtom's Avatar
Do one side at a time have the rear end up and both tires off so you can reference the springs on the untouched side of the drum brakes.
Check your front pads for uneven wear,more wear on one pad could mean stuck sliders or a seized caliper.
transamtom is offline
Old 12-07-2012, 09:28 PM
Evolution223's Avatar
yeah, what he said, make sure the caliper pins arent seized, if they are you can get a rebuilt caliper for about $50 at any auto parts store, and make you you use proper lube for the pins.
Evolution223 is offline
dluna333
15
03-13-2015 12:30 PM
Jazsun
12-29-2014 12:14 PM
Red97LT1
9
12-17-2014 06:13 PM
Hurin
12-13-2014 07:38 PM
Quick Reply: Replacing brakes yourself
