throttle positon switch
Old Mar 24, 2003 | 08:37 PM
irocz8957's Avatar
Question throttle positon switch
i was wondering wear the throttle position switch is on my 89 irocz 5.7, i read turning it will raise the voltage and will give you better throttle response!!
Old Mar 24, 2003 | 09:21 PM
1fastformula's Avatar
It is located on the passenger side of the Throttlebody....right above the IAC (Idle air control) valve. I have done this and felt a little SOP response...... Good Luck
Later
Old Mar 25, 2003 | 07:16 AM
Jim85IROC's Avatar
Leave it alone. Any SOTP gains are all in your head. At best, all it's going to do is provide a little more part throttle grunt. At WOT it won't feel any different.
Old Mar 25, 2003 | 07:54 AM
87DJP2001's Avatar
Re: throttle positon switch
Not a good idea , just leave it alone unless you want problems with the Idle and driveability. Not a power adjustment.
Beave2780
Jul 7, 2015 06:36 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Redbird
Sep 5, 2002 08:36 PM
