Using GM top engine cleaner
Old Mar 22, 2003 | 03:43 PM
94hawk_klf's Avatar
I bought the spray kind. Using it on a 98 Z28. What is the procedure to use it in an LS1?
Is the other kind(pour) better?
Old Mar 22, 2003 | 09:24 PM
JimMueller's Avatar
I've used the spray kind on my car once, but only let it sit for ~3-4 hours. I removed the bellows from the throttle body, and moved the lid/MAF/bellow assembly to the side. I then held the throttle blade open a bit and sprayed it into the bottom of the throttle body. Need to go slow, took about 5 minutes to empty can. I let the idle die when the can emptied and removed the key.
I've heard that it works better if you use the kind which gets sucked into the booster line. I don't recall the specifics on that method, sorry.
Old Mar 24, 2003 | 02:29 AM
TerrorDome's Avatar
you can try a search. theres a lot of other things involved, i think you have to drive around and a lot of black smoke comes out of your pipes. then you're supposed to change your oil right away.
i think...but do a search to be sure.
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
