Crap
Old Mar 22, 2003 | 08:48 AM
OffspringZ28's Avatar
Crap
well my nozzle was put in my stock rubber elbow which after time cracked and loosened up the nozzle, well i have been hunting my stumbling, sputtering problem which seemed to occur right after the nitrous install. I thought the hole in the bellow was the culprit but i replaced that with the trick flow (shiny ) which did improve the cars performance, noticeably. however, when i looked on the inside of the stock elbow and looked at the nozzle, it wiggle itself around and was facing the MAF... can spraying a wet shot on the maf do damage to it? im pretty sure it can, and my o2's are gone. so what do you guys think?
Old Mar 22, 2003 | 11:36 AM
Z28ROC's Avatar
I doubt it damaged your mafs. It probably spun around while you were removing it. Otherwise you would have noticed the lines were crossed over each other. Or maybe not.
Old Mar 22, 2003 | 12:51 PM
stik6shift98's Avatar
hmmmmm... does spraying fuel onto the maf sound like a good idea
i dont think so
Old Mar 23, 2003 | 09:53 PM
is stumbling/sputtering symptoms of a bad MAF?
Old Mar 29, 2003 | 01:14 AM
11sec's Avatar
I would spray a wet kit in the wrong direction. what would happen the the fuel?
magman
Apr 15, 2016 03:08 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
jayblev95
Sep 26, 2015 09:44 PM
colts0455
Sep 22, 2015 02:03 PM
