nitrous
Old Mar 21, 2003 | 09:49 PM
Kearn's Avatar
nitrous
i don't have the first clue about nitrous, and am planning on getting a set up in the near future and was hoping someone out there can help me out with some questions.
1. what's the difference between a wet kit and a dry kit nitrous system? and what are the advantages of one over the other?
2. what are those cheater systems or whatnot for?
3. is 120,000 miles too much for 100 shot of nitrous?
4. will nitrous damage my engine? i've heard that nitrous is really bad for an engine in the long run.
that'll do it for now. thanks for any help you can give me.
Old Mar 21, 2003 | 11:43 PM
bachehbad's Avatar
ttt
Old Mar 21, 2003 | 11:48 PM
94T56T-TOPDREAM's Avatar
maybe try posting in the N20 board ...might get you more responses
Old Mar 21, 2003 | 11:50 PM
chesee48's Avatar
Post in the N20 Section for more answers and replies.
Old Mar 22, 2003 | 12:15 AM
ChrisJ325's Avatar
Re: nitrous
1. wet kit has its own "fuel system" in that it sprays fuel and nitrous through the jets.. dry kit sprays only nitrous and relies on the MAF to alot for more fuel to spray from the fuel injectors. wet kits hit harder than dry kits in my experience, but you need good bottle pressure to get full advantage from a wet shot.
2. never seen a cheater system for an LT1, those are a type of kits for carbeurated cars unless ive missed something new or am thinking of something different. not sure on that.
3. if you arent burning oil, coolant, etc and your motor doesnt have any problems, then i would think you would be ok.
4. if you dont set it up properly, yes, nitrous can damage your engine. if set up properly its no more stressful than having the extra power NA or through a blower/turbo. In fact it may be less stressful because the power isnt there the whole time, only when you are racing and want it there.
hope that helps.
Old Mar 22, 2003 | 01:00 AM
NXz28's Avatar
search for safety items...
n20 is pretty safe and not bad on your engine as long as you use common sense...
get a fuel pressure safety switch, wot switch, window switch.....you'll probably also want a purge kit to show off the nitrous system
Old Mar 22, 2003 | 08:32 AM
Brent94Z's Avatar
Super Moderator
I'll move this over to the Nitrous forum for ya...
Old Mar 22, 2003 | 11:43 AM
Z28ROC's Avatar
Here's some good reading from Dave Mills.
www.go-fast.org/z28/new_to_nitrous.html
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
