Blow down tube...
Old Mar 20, 2003 | 06:08 PM
craigffb's Avatar
Blow down tube...
What all do you need to put a blow down tube on, and will any one work..ie NX, NOS and so on?
Old Mar 20, 2003 | 06:18 PM
stik6shift98's Avatar
what kit do u have....why not just get the one from the brand kit u have...i have nx and have the nx one it was simple to install
Old Mar 20, 2003 | 06:27 PM
craigffb's Avatar
I have a NX kit, but I would have to order it from some place when I could just pic up a NOS one from one of the parts stores here on the Island. But do I need the "Blow-off Cap" as well? How does It hook up??
Old Mar 20, 2003 | 06:59 PM
snow2000SS's Avatar
The NOS one would not work very well it is a 90 degree and belive you need a 180 degre to fit the NX bottle.
Old Mar 20, 2003 | 11:38 PM
craigffb's Avatar
OK, got it. It's best to get the NX one. But do I need to get the Blow-off cap?
Old Mar 21, 2003 | 08:21 AM
oh yeah you do need the 180 one...
Old Mar 21, 2003 | 09:52 AM
craigffb's Avatar
Ok, I need the NX tube. Do I need to get the Blow-off Cap for the tube to work, or will the bottle just blow up in the trunk???
Old Mar 21, 2003 | 10:12 AM
snow2000SS's Avatar
Not sure not real up on the NX stuff try giving them a call
Old Mar 21, 2003 | 10:40 AM
JodyJ's Avatar
Yes, you will need the Blow Off Valve. This is what it looks link: http://jody.dltechnologies.com/share...owOffValve.jpg
The tube that came with my Gen II kit was short, so I went to the local hardware store and purchased 3ft. of 1/2" aluminum tubing. Custom bent it to fit in the truck and out the rubber grommet on the bottom of the spare tire area. I used the same fittings from the original tube and used a flaring tool to flare out the ends and that's it. Total cost was $6 for the tubing.
Hope this helps.
Jody J.
Old Mar 21, 2003 | 10:43 AM
Ed Blown Vert's Avatar
You need to change the the blowoff cap so you can attach the blowoff tube. Don't forget to change the Pressure Relief Disc.
Old Mar 21, 2003 | 10:58 AM
craigffb's Avatar
Thanks. Now I know what I need to get.
Old Mar 22, 2003 | 02:10 AM
hope everything works out good for you
Old Mar 22, 2003 | 11:48 AM
Z28ROC's Avatar
Don't overtighten that fitting when you put the new one on. It will damage and weaken the disc. Also make sure the bottle is completely empty before changing them out.
Old Mar 22, 2003 | 04:22 PM
kirschman's Avatar
get a bulkhead fitting for the floor. Screws to the tube, makes it alot cleaner look
Old Mar 22, 2003 | 10:25 PM
snow2000SS's Avatar
Z28ROC good point. I see alot of saftey disca blow becuase they are over tightened. We usually recomend hand tigh then 1/8 turn. Then if it leaks tighten till it stops leaking and you're done.
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
