What temp does your gage normally read?
Old Mar 20, 2003 | 01:10 PM
Ninja02's Avatar
My gauge used to stay right about 185. I noticed it up around 210 last week and I checked the coolant and it was low. At this time I flushed the radiator and refilled it. I've checked the level and it is fine and I haven't found any leaks. But the gauge doesn't hold steady at 185 like it did before. When I'm sitting in traffic it goes up to about 210 but once I start driving and air hits it, it goes back down to 185. My friend said it's normal but I don't ever remember it behaving like that before. Is this normal or should I investigate further?
Old Mar 20, 2003 | 01:43 PM
V6 Punk 93's Avatar
Its normal to go up higher when sitting in traffic, just as long as the gauge isn't in the red.
Old Mar 20, 2003 | 02:15 PM
kahouna23's Avatar
mine has been in between 190-210 ever since I bought the car new in 99'. I just flushed my radiator yesterday for the first time........My antifreeze was BROWN!!! I ended up flushing it three times before I got most of it out. I don't even want to know what my hoses and thermostat look like.
NINJA02: did you ever find the drain plug you were asking about? I have no idea where it is, the only drain I know of is the one on the bottom right side of the radiator itself.
Old Mar 20, 2003 | 03:33 PM
ImportKILLER's Avatar
I don't really like the Dex-Cool coolant nor do I trust leaving the coolant in for 5 years/100,00 miles so I flush and refill right before each summer.
My temps are usually at the line above the 160 or just slightly over it...I mean just a hair over the line. It is natural for the car to climb when sitting at a red light, traffic, etc. I've been in other F-bods and the temps in those cars climb just the same as mine. Funny...the temp gauge in my girl's Mustang never climbs, even in traffic.
Old Mar 20, 2003 | 03:37 PM
Satellite98's Avatar
286 degrees.
180-190 while driving, and 190 sometimes 200 while idling.
Mine does that occassionally (in warmer weather,not lately), usually the fan will kick on (after awhile) and send it back down. But 210 doesn't sound bad. Hell my blazer goes to 230 (no joke) when I used to go through a drive thru in 85+ degree weather.
Old Mar 20, 2003 | 04:16 PM
99blackSS's Avatar
My V6 would almost always stay at 185 until I did the FRA mod and then it would warm up at long stop lights.
Old Mar 20, 2003 | 06:19 PM
Bliggida's Avatar
When you refill the radiator/ add coolant make sure you have the heater turned on full. You'll end up taking about a half to full gallon of more coolant!!!.
If coolant goes down too low, the heater won't work well. I tried changing thermostats but until I checked the fluid level, and refilled, a T'Stat didn't make one differance.
With a 195 unit, it goes about 185 driving, and climbs around 210 at long long stops.
...if I stop more than a minute I shut down. Waste gas, heat climbs, etc. I need to install the manual fan control switch.
Old Mar 20, 2003 | 06:54 PM
1fastV6's Avatar
whenever you want we can do it at my house. there is a radio shack down the street, or you can be like me and waste all that money for the slp one. i thin it just looks nicer and is easier to install the slp though.
Old Mar 20, 2003 | 06:55 PM
Bliggida's Avatar
What does the Radio Shack version require buying?
Old Mar 20, 2003 | 06:59 PM
1fastV6's Avatar
thin wire and a toggle switch
and a led if you want to get fancy - i have detailed instructions at home
$10 and its in, and that includes the burgers we'll eat afterwards
do a search on the other board and you will get the step by step. but i still have them at home.
Old Mar 20, 2003 | 07:04 PM
Bliggida's Avatar
Well so long as Mark will sell me a fog light switch for anything under 200 dollars, then maybe I'll get one and make appear as a factory option.
Old Mar 20, 2003 | 07:31 PM
kahouna23's Avatar
do you think you could post a link to the install instructions. I'd like to do this myself as well. thanks
Old Mar 20, 2003 | 08:30 PM
1fastV6's Avatar
here is one i found
http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=006716
it seems that the link that everybody was using 2 years ago has dissapeared.
i have it printed at home
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Drag Bear
Jul 22, 2002 05:38 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
