Where is the coolant drain plug for engine?
Old Mar 20, 2003 | 11:49 AM
Ninja02's Avatar
I can't seem to find anything in my Hayes book about where the drain plug is for the engine block on the 3.8. Can someone help me out here?
Old Mar 20, 2003 | 06:29 PM
Bliggida's Avatar
For Coolant you drain that through the radiator. Look on the lower driver side of the radiator, on the engine side. Should see a petcock there, that will drain coolant.
IF you are trying to drain the oil, the drain plug is on the oil pan.
Those are your only two options.
Don't forget Dex-Cool is different from regular coolant.
Old Mar 20, 2003 | 07:33 PM
Tom Richdale's Avatar
If you just need to drain the radiator that's on the bottom of the radiator on the passenger side. If you need to drain the block as well, you'll find the block drain plugs on the left and right hand sides of the block slightly above the oil pan rails by the middle of the engine.
Alex Barnes
Jan 24, 2015 10:21 PM
Sandersen511
Jan 13, 2015 03:49 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
ARFFormula
Aug 3, 2002 09:55 PM
