New to nitrous, couple of questions...
Old Mar 19, 2003 | 10:15 PM
94 CAMRO Z28's Avatar
Hey there, I've been thinking of adding Nitrous to my car after I do my ported heads. I guess the question I have is what safety regs would I have to follow to be legal at the track? Is there anything special I would have to do that wouldn't be included within a "kit". Also, what is the difference between a dry vs. wet shot and what is better? Thanks
Aaron
Old Mar 19, 2003 | 10:40 PM
stik6shift98's Avatar
i like my nitrous like i like my women......WET!!!!!!!
and i think u have to have it mounted securely and a blow down tube....then u will also have to have a driveshaft loop....
Old Mar 19, 2003 | 10:44 PM
Blue89Bird's Avatar
for an lt1 get a wet kit.
too be legal you need a blowdown tube
too be safe you need a wot switch, a fpss, if you have a stick you should get a window switch as well.
Old Mar 20, 2003 | 01:34 AM
What exactly is a blow down tube? How much do they cost? Install hard at all? Thanks
Aaron
Old Mar 20, 2003 | 07:43 AM
Blue89Bird's Avatar
on your bottle, one end of the fitting gets connected to your feed line which you run to your intake, the other gets connected to the blow down tube, you then drill a hole wherever the bottle is mounted through the floorboard, so that it "blows down" outside the vehicle.
Old Mar 20, 2003 | 03:46 PM
Twice The Fun's Avatar
my kit came with a blow down tube, and i still havent istalled it....lol......but i defineatly recommend a WOT switch and window switch, just for the safety aspects.....low rpm nitrous backfires are killer let me tell you!
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
4586
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
