74 vette with a 72 Z28 block question
Old Mar 19, 2003 | 08:08 PM
74vertvette's Avatar
Hello from Texas to the Camaro owners....
Maybe you all could give me some help. I do not own a Camaro, but pulled the matching #'s engine on my '74 vert vette and am going back in with an AR Racing 355/427HP Dart head engine that happens to have a '72 Z28 block.... or it appears so. The block casting is 3970014... date coded A26 72 and the I.D. pad is stamped 10214CKA. From everything I can see it probably came out of a 72 Z28 Camaro.
The question I have is about the oil pressure sensor on the blocks of 72 Z28's. My 74 engine had a threaded pipe right above the oil filter that attached to the oil pressure sensor. This block does not have that. Where exactly is the oil pressure sensor on your blocks? It would be appreciated.
Here's a pic of the engine that is about to go in just to let you see what I am working with.
Old Mar 24, 2003 | 12:36 PM
Z28SORR's Avatar
Drivers side top next to the distributor on the same surface as the intake aft seal.
Old Mar 30, 2003 | 06:27 PM
twozs's Avatar
if it were an engine out of a 72 z28 it would have had on the pad on the passengers side infront of the head a number letter sequence that ended with ckt (auto) or cks (4 speed). dont really know what a cka is out of
Old Mar 31, 2003 | 03:03 PM
Jeff H's Avatar
CKA is a 350/165hp engine with a 2 bbl carb. No Z28 engine there.
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
