free ram air Q's
Old Mar 19, 2003 | 07:19 PM
2000camaroRS's Avatar
free ram air Q's
can the free ram air mod be done without the threat of it sucking water into the engine or something like that happenening?? and the same with the rksport ram air and whisper lid...is there a danger of them sucking in any unwanted things???
Old Mar 19, 2003 | 07:32 PM
Bliggida's Avatar
Yes. There is virtually no "Ram-Air" system that will suck in water.
Water coming into the intake sounds like a feesible idea, and true if water did get into the intake it could cause damage.
However, the problem with that theory is that
Water is too heavy to be gulped in without PSI behind it. So, with a supercharger, yeah maybe...maybe.
Now your Air intake may be a little wet if you just ran through a puddle at a speed you shouldn't be running through puddles in. But unless you actually submerge the air intake (put the hood under water) the chances of you bringing water into the engine are very minimal.
The Free Ram Air Mod, you really don't need to worry about. If anything, worry about something like the FTRA, and even then, they are completely safe so long as your are smart and responsible.
Old Mar 19, 2003 | 11:56 PM
F1GT's Avatar
I think you are better off to do the raised air box mod. The FRA mod is just a hassle. Lots of crap just get sucked into the filter. You see a black strip with tons of little pebbles and tiny debris in no time. The air filter gets damp from a down pour, even though you make sure not to follow cars/trucks to avoid the mist getting kicked up at you. I blocked mine off. A lot less crap to shake out of the filter.
But, if you don't mind having to deal with a constant dirty filter and having to clean it(K&N,Holley) often, then by all means, cut it up.
Old Mar 20, 2003 | 04:08 PM
99blackSS's Avatar
Yup, I did it on the V6 Camaro. Got a black strip right away plus pine needles. The gain is very minimal, not worth it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
Viper
Jul 30, 2002 02:06 AM
