stroker motor???
Old Mar 18, 2003 | 08:53 AM
J-Roc1981/1997's Avatar
stroker motor???
What would be the best kit to buy to build a 383 stroker? I have a 81 z28 with the 350. Thanks for the help?
Old Mar 18, 2003 | 10:14 AM
You will probably get a better response to this on Classic Tech or maybe even 3rd Gen Tech. There are a number of engine shops that will sell you rotating assemblies, short blocks, long blocks, etc. You will need to define what your plans are.... all motor, nitrous, blower, street, strip, etc.
In general, basic questions regarding "strokers" are best answered on forums dedicated to specific generations.
Moving to Classic Tech....
Old Mar 18, 2003 | 11:55 AM
69camaro383's Avatar
Call this guy or emial him. His name is Beau. Tell him James with the yellow 69 camaro told you to go through him. He gives really good deals and will help you find a good kit.
http://www.mentaladdictionmotorsports.com/
Old Mar 20, 2003 | 11:13 PM
11secgen's Avatar
stroker
are you going to use your block,rods or any other stuff off your 350?all you really need to buy is a 400 crank and pistions.
try to get a 400 crank from a salvage yard.i bet you could get one for under $50.get it cut for 350 mains for about $75 and throw in a set of $200 hypereutectic pistons from keith black and youve got a strong street/strip motor.strokers make power at a lower rpm than stock stroke motors ,so they can achieve a higher h.p. potential without having to buy costley forged engine components,because you dont have to spin them as high.are you going with stock heads?what rear end gear are you running?auto or 4 speed?cam selection is critical on these motors,so let me know what you have and ill give you my recomindation
Old Mar 21, 2003 | 07:33 AM
jy211's Avatar
you could always go for a GM crate motor. Check out fastburn motors....
Old Mar 29, 2003 | 11:01 PM
fordkiller94's Avatar
Talking
summit racing and performance automotive warehouse and northern auto parts all sell 383 kits cheap---499-699 dollars. its easy, build it yourself...i have a 534hp 383 stroker in my 68 camaro i built 4 years ago with a PAW kit, still running today...
D1SC383LT4
Jan 1, 2016 01:56 PM
Sauced
Apr 12, 2015 10:18 AM
Rde Bandit
Mar 21, 2015 10:17 PM
squirrels
Jul 13, 2002 01:58 AM
