Fuel pressure safety switch and window switch...
Old Mar 17, 2003 | 10:22 AM
craigffb's Avatar
Anyone running both? I so hw did you wire it? Can they be wired in line or will it not work that way??
Old Mar 17, 2003 | 07:49 PM
stik6shift98's Avatar
i think 1 of those is fine....
i have fpss
i know ppl have done both b4...im guessing wire them in line
Old Mar 17, 2003 | 08:16 PM
craigffb's Avatar
i have fpss
That's what I'm thinking too, but I'm not sure if they would cancel each other out. I would think so. Anyone.
Old Mar 17, 2003 | 08:29 PM
hmmm good luck u got me on that one too
Old Mar 17, 2003 | 09:21 PM
Blue89Bird's Avatar
the fuel pressure safety switch has one end that gets connected to the relay, the other end gets grounded. the ground from the solenoids is what gets connected to the window switch.
Old Mar 17, 2003 | 09:30 PM
craigffb's Avatar
Ok, I think I've got it now. Does this sound right?
NX relay:
Red to WOT switch
Black o 12 V
White to FPSS to ground
Green to solenoids
MSD:
Black to ground
White to tach lead on Accel 300+
Red to 12 V
Yellow to solenoids ground
Now is it right
Old Mar 17, 2003 | 09:39 PM
sounds good to me!
just wait till a couple more people reply to make sure...
Old Mar 17, 2003 | 09:43 PM
craigffb's Avatar
That's what I hope will happen
Old Mar 18, 2003 | 08:19 AM
Blue89Bird's Avatar
looks right to me as well
Old Mar 18, 2003 | 09:08 AM
95greendragon's Avatar
I know that White to FPSS to ground is correct and I am 99.9 percent sure the rest of it is correct.
Old Mar 19, 2003 | 11:17 AM
phil46y's Avatar
Here's a link to the wiring schematic I used; Hope it'll be of some help.
http://temp.corvetteforum.net/c5/rwj...ouswiring2.jpg
Old Mar 19, 2003 | 11:12 PM
craigffb's Avatar
That one is useing two relays, which I hadn't planned on doing.
Old Mar 20, 2003 | 12:19 AM
Drew778/94Z's Avatar
Talking
Just put both on the side, they just add more weight.
Thats why I just left that safety stuff off.
Just waiting for the big BOOM now, maybe the 150 shot will do it.
Old Mar 20, 2003 | 01:19 AM
craigffb's Avatar
Your nuts and my car is old. I should have all the stuff soon. You gonna help me put it in?
Old Mar 21, 2003 | 11:46 AM
Yep!
Maybe I'll put some safety stuff on my car.
