1981 z28 air induction
Old Mar 17, 2003 | 08:44 AM
J-Roc1981/1997's Avatar
Question 1981 z28 air induction
How does the air induction on the hood work? I bought a 1981 camaro z28 and the air induction does not work. I have 2 wires hanging down one orange and one black. Where do the wires go? The shop manual doesn't have it in it. Any leads would help.
Old Mar 17, 2003 | 09:53 AM
11secgen's Avatar
cowl hood
the orange wire goes to a throttle switch on the carb,and the black goes to ground.if you mare missing this switch you can use one that is supposed to be used to accuate nitrous at w.o.t.(wide open throttle)you can easily modify this switch to open at 3/4 throttle.look in the nitrous section of summits catalog.
Old Mar 17, 2003 | 12:06 PM
where does the switch go on the carb?
Old Mar 17, 2003 | 01:30 PM
will part #NOS-15640 work? Thanks for your help.
Old Mar 17, 2003 | 01:35 PM
Erik's Avatar
Classic Tech Moderator
On my car, the wires go to a switch under the gas pedal - when it's floored, you hit the switch.
Maybe it's different between 80 and 81?
Old Mar 17, 2003 | 03:48 PM
Dirt Reynolds's Avatar
You are right, Eric. The air induction door is activated by a solenoid, which gets its signal from a switch on the gas pedal arm. When you floor it, the switch grounds and the solenoid opens the air induction door. Its the same for both 1980 and '81. I've had 2 1980 Z/28's and they both had the same system as my buddy's 1981 Z/28 (which he bought brand new in 1981 and still owns).
Dave
Old Mar 17, 2003 | 03:53 PM
So where do the wires go to on the soleniod? Can you still buy these soleniods? and if so where? Will the nitrous switch work? thanks for the info!
Old Mar 17, 2003 | 04:06 PM
The solenoid is around $50 or so from The Paddock.
Dave
Old Mar 17, 2003 | 07:55 PM
Erik's Avatar
If the air induction is not working, check to make sure it's not just the switch. On my car, the switch was faulty, and a new one was only about $15 CDN.
Old Mar 18, 2003 | 08:45 AM
where do the orange and black wires go? on the solenoid?
Old Mar 21, 2003 | 09:32 AM
scott 81 z28's Avatar
yeha i just bought a 81 z28 about 3 weeks ago and i was looking at that b/c my wires r just hanging there too and i didnt know where they went.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
The Seer
Nov 24, 2014 07:59 AM
BM93Z
Aug 22, 2002 02:45 PM
