my frustraiting car
Old Mar 16, 2003 | 08:52 PM
jtj2000's Avatar
my frustraiting car
well now my car is having more problems. When it is in idle, it spudders and isn't smoothe. When I press the gas a little it rumbles and doesn't accellerate smoothly. And when i hit the gas hard there is a big pop. My dad said at first it might be a fuel pump, and then said something about some regulator under the hood. I don't know he's checking with napa and with some mechanics he knows. Well what do you guys think? And do you really think replacing the brake rotors is necessary if they seem to work fine? Is there a visual way to tell just by looking at them if they need to be replaced? Thanks for all your help -
Jason Huneke
Old Mar 17, 2003 | 09:13 AM
kahouna23's Avatar
sounds to me like the "infamous" misfire problem. Get new plug wires and your worries will just mysteriously go away.
Old Mar 17, 2003 | 09:47 AM
GrdLockV6's Avatar
Sounds to me like your car's been hanging out w/ nino's car too much and caught it's disease
As for the rotors, if your car shakes when you stop, they could use some turning or replacing (still not an emergency), but no big deal.
Old Mar 17, 2003 | 03:40 PM
jtj2000's Avatar
well i just installed new spark plugs and wires a few weeks ago. Could it be one fell off or something?
Old Mar 17, 2003 | 06:49 PM
kahouna23's Avatar
most definately....either doesn't have a good connection or burnt through, due to inproper routing. Very good possibility
Old Mar 18, 2003 | 12:42 AM
camaro6's Avatar
My car was idleing rough kind of like yours. I took it in to a shop to have it looked at and they said the throttle body was dirty, so they cleaned it and now everything is working good. So this might be a possibility too.
Old Mar 18, 2003 | 09:35 PM
jtj2000's Avatar
I took off each spark plug at a time from the coils, and all but one had sparks comming from it. Should I buy a new coil? could this be the problem? I didn't check the actual spark plugs because i would have to jack the car up again and I just didn't want to do that.
Old Mar 18, 2003 | 09:50 PM
kahouna23's Avatar
Yeah...........new coil. Just spend the extra money and get an MSD Dis-4 ignition. Just my opinion. I'm sure your car is still under warranty. That's covered by the way.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
