Re-tightening header bolts
Old Mar 14, 2003 | 11:47 PM
camarol32's Avatar
Ok, I'm going around snugging up my header bolts. I get all of them except for the passenger side one on the bottom in front right above the AC compressor. I've worked for 2 hours trying to figure out a way to get something on this. Nothing works! I'd like to try and avoid removing the compressor to get to it, b/c it is going to be a pain in the *** to get it back in place with the primaries running right by it. Have any of you got some Ideas? Should I worry about it that much?
BTW this is on a 95 3.4
Thanks for any help.
Old Mar 15, 2003 | 01:46 AM
Bliggida's Avatar
You could *try* seeing if there is enough A/C line for you to unbolt the A/C compressor with the lines attached, and move it a few inches away just long enough to get a ratchet on that header bolt. Then re-stab the A/C compressor. The key to all it is to be very careful with those lines and put the least amount of pressure on them as possible.
If you don't have a buddy to help you by holding the compressor, support it with something so the lines are not bearing its weight.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
