Changing the bulb of the map and dome lights?
Old Mar 13, 2003 | 06:26 PM
syacoub's Avatar
This may be a stupid question, but i don't want to break anything, i just want to be sure. I want to change my bulbs in the map lights under the rear view mirror and the back dome light.
So do the clear lenses on the map and the dome just pop up?
Not sure if there is a trick to the map lights. Also not sure about the dome either.
Thanks!!!!!!!!
Old Mar 13, 2003 | 06:33 PM
Smokinsometires's Avatar
Just pry off the map light plastic covers with a small flathead screwdriver. The dome light plastic just comes right off with a flick of your wrist!
VERY easy.
Old Mar 13, 2003 | 07:14 PM
95_RipperZ's Avatar
Those bulbs are way up in there though and you will need to use soemthing to pry them out too. A little PITA trying to get them back in too but not too bad.
Dec 1, 2016 05:37 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Amshnock
14
Jan 18, 2015 11:47 AM
David Dorris
Jan 17, 2015 08:10 PM
squarehead
Jan 15, 2015 07:02 PM
