New lighter FLwheel
Old Mar 12, 2003 | 06:59 PM
T.O_Camaro's Avatar
New lighter FLwheel
Okay, I need advice from someone who knows exactly what they are talking about. Will a lighter flywheel then stock help me in my situation and what improvements will i see with this improvement.
Im replacing the stock 350 flywheel and clutch of my turbo 350 in da 79 camaro.
Old Mar 12, 2003 | 07:42 PM
CoryM's Avatar
A lighter flywheel will allow the engine to rev up faster and higher, but will lose engine momentum while shifting. Which is more impoertant I am not sure. I have been advised by a few very knowledgeable racers to use a 12" flywheel/clutch. Mostly for the extra clamping power but also because it will keep the momentum going when shifting. I hope someone can definatly explain which is best for each application as I am curious as well.
CoryM
Old Mar 13, 2003 | 11:24 PM
Silver Pig's Avatar
Cory has the idea down good!
What will you be doing with the car? If it is going to be a weekend toy with no track time I would say hit up the lighter or an aluminum flywheel. However, if you do take the car to a track you will have holy hell with it! I just ripped my aluminum flywheel out of my car, I couldnt stand it!!! All the car would do was either bog and fall on its face or spin its *** off out of the hole!
It is just up to you and how you want the car to perform in your conditions.
Sean
Old Mar 16, 2003 | 12:21 AM
CoryM's Avatar
Silverpig.... I am thinking that the light fly wheel would be best in a road racing car. You dont really need the momentum of the fly wheel as much then as on a lauch. Did your car rev up easier with the lighter flywheel when you gassed it w/o downshifting? Or was that part of it not very noticable? My car isnt meant for straight line stuff so Im curious.
CoryM
Old Mar 18, 2003 | 11:30 PM
Silver Pig's Avatar
CoryM
Yes, the revs were way more responsive than the steel set up! I am going back to steel because I could not get a consistant launch at the dragstrip! The best I pulled was a 1.64 60ft! with 506 rwhp!!! Plus the car weighs in at 3090 lbs with me (211lbs) in it.
Trial and error they say eh...
To those who dragrace: Forget about aluminum flywheels!?
Sean
brothaslide
Jan 9, 2016 12:11 PM
NewsBot
Sep 14, 2015 08:50 AM
Jlo
Jul 29, 2015 03:52 PM
eanhl2004
Apr 4, 2015 12:01 PM
NewsBot
Mar 30, 2015 11:31 AM
