Ign. Fuse Popping
Old Mar 10, 2003 | 09:25 AM
IllusionalTA's Avatar
Ign. Fuse Popping
Well went to the dyno yesterday did a few pulls'.. On the last pull i added 1.5 degree's from 2800-6300 throughout the band. WEll it all worked well.. While sitting in the parking lot it. Just died.. Did some research put the other prog i had in it in and what not and ultimately discovered it was a blown Ign. fuse.. Cool.. Why? i have no idea.. So i changed it and voila.. Fine all day yesterday and what not.. WEll thinking it was a freak thing.. I re up'd the prog and sure enough it popped again same thing.. drives fine and then for no reason pop's it.. Anyone have any insight where to "Start" to look.. ONly when i add timing.. Otherwise it don't do it..
Old Mar 11, 2003 | 08:06 AM
ttt
Old Mar 11, 2003 | 09:40 PM
97 RedSS's Avatar
Seeing you have a water pump how did you wire it?
I bet you wired your water pump to get power from the ign circuit..If so, you are overloading that circuit since the pump does pull 9amps..You need to wire it in via a relay so you can get the water pump on a seperate circuit..
Cody
Old Mar 12, 2003 | 02:22 AM
The water pump is wired through a relay. I don't have the problem when i have my normal tune in.. Which is whats stumping me.. Only when i bump it up 1.5 degrees does this thing randomly pop..
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
