Can I use this t-56 with this much torque?
Old Mar 8, 2003 | 02:02 AM
Green95Z28's Avatar
I've got a t-56 sitting on my shop floor right now that has no 3rd and 4th. I was wondering since I have to rebuild it anyways is it possible to build one for a motor that makes upwards of 600 ft/lb of torque at the flywheel? This is going to be a street/strip application so I am thinking that if i can't build it for that should I just stay with the th400 thats in it now?
Old Mar 8, 2003 | 04:40 PM
Bliggida's Avatar
I've seen T-56's behind 800+ Ft-lbs. You will have to performance rebuild it, but after that you shouldn't have any problems.
Old Mar 9, 2003 | 02:45 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
it can handle it! 2 tips.... first is upgrade the 3/4 shift fork to a viper ashift fork, second, send gears, cluster , input, and output shaft out to be cryogenically frozen, then buy a mcleod street twin.
trust me i know from experience
G-BODYT56
Jan 14, 2022 11:14 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
