Another T-56 swap question in which Search Cannot help.
Old Mar 4, 2003 | 11:03 PM
BlowBye's Avatar
Motor is an 87 TPI, but the T-56 is from a 95' bird, will the starter from the 87' work on the T56? Will it sit on the bellhousing without any problems? thanx
Old Mar 5, 2003 | 01:13 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
It depends. Most people say their automatic starter will not work but I know a couple people who say theirs did. I had a T5 starter and it bolted up just fine.
Old Mar 5, 2003 | 02:56 AM
stk350's Avatar
I did the a4 to a m5 swap and the nose on the auto starter was to big for the bellhousing. I would imagine that the same would go for a t-56.
Old Mar 5, 2003 | 07:02 AM
Jim85IROC's Avatar
Anybody that swapped to a manual and didn't have to change their starter already had a manual starter and didn't know it.
Old Mar 5, 2003 | 11:39 PM
BlowBye's Avatar
Thanx guys, Just to note, i did have a T-5 and since the LT1 has less flywheel teeth, i thought that starters were different. thanx
Old Mar 6, 2003 | 11:54 AM
Jim85IROC's Avatar
What do you mean the LT1 has less flywheel teeth? The LT1 has 153 teeth, just like the thirdgens use.
Old Mar 6, 2003 | 06:44 PM
BlowBye's Avatar
whoops, i thought third gen flywheels had 168 my mistake, thanx for correcting jim.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Deadbolt24
Jan 19, 2015 01:29 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
Hurin
Dec 13, 2014 07:38 PM
