Everyone with modified Monsoon systems in here...
Old Mar 4, 2003 | 01:25 PM
raveIKON's Avatar
I'm looking to get the correct adapters and add a driver's side subthump box and possibly a passenger's side one too. I'm going to keep the stock head unit (or I was planning on it).
But to turn the volume to the max, it seems like the stock speakers would blow unless you could somehow put a crossover on them.
How can I handle that?
Old Mar 5, 2003 | 12:36 AM
stik6shift98's Avatar
adjust the amp
Old Mar 5, 2003 | 07:07 AM
raveIKON's Avatar
And how exactly do I adjust the Monsoon amp?
Old Mar 5, 2003 | 03:32 PM
open trash...insert stock monsoon amp...purchase aftermarket amp.....install and there u go
Old Mar 5, 2003 | 05:52 PM
DrMilhouse's Avatar
The monsoon amp can not be adjusted. You will need to adjust the amp of the aftermarket amp that you use for the aftermarket subs that you install.
To complete this you will need a LOC (Line Output Converter) to send an RCA line level signal from the head unit to the aftermarket amplifier. You'll need the aftermarket amplifier and you'l need the aftermarket subs. That along with some cabling is all you'll really need.
complex
Sep 10, 2002 01:09 AM
peptide
Aug 27, 2002 11:26 AM
30thZ286speed
Aug 3, 2002 04:54 AM
Brian-94TA
Jul 31, 2002 02:52 PM
'StangSlayer
Jul 25, 2002 04:13 PM
