TB bypass in SC application
Old Feb 25, 2003 | 10:52 PM
BPS's Avatar
BPS
I've been reading the latest bunch of posts on the lt1 board discussing the rational behind doing a TB bypass.
It occurs to me that under an SC applicatin the benefit of this mod is even more problematic. Our air temp is higher than in NA cars and most of us run a 160 thermo and lower fan settings so the coolent through the TB actualy may cool things a bit rather than heat the incoming air.
I doubt the TB bypass has much impact in any application but even less in an SC one.
comments?
Old Feb 26, 2003 | 10:56 AM
95greendragon's Avatar
Correct air temps are increased but there is no way the coolant is at a lower temp then your incoming air temp. Therefore the coolant would have a heating effect. Here's a dyno test.
http://ws6.com/mod-8.htm
Old Feb 27, 2003 | 05:01 PM
stik6shift93's Avatar
Not to mention after you do the bypass, the throttle body will be able to disappate heat from the intake charge. So indeed you will pick up some horsepower
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
