basic routing question
Old Feb 25, 2003 | 09:40 AM
GoFast908Z's Avatar
Member
how do i find the hole in the firewall to sneak the power wire for my amp into the engine compartment and to the battery?
Old Feb 25, 2003 | 09:50 AM
LS1 RULZ's Avatar
Under the hood on the passenger side you'll see the PCM. Its far back towards the windshield next to the hood's hinge. You'll see a lot of wires going into a couple of harnesses that plug into it. Theres 2 10mm bolts that hold it in. Remove the 2 7mm bolts holding the harnesses in and set the harnesses aside. Then remove the 2 10mm bolts holding the PCM secure. Now you can turn the PCM sideways so that the part where the wires went is now facing the passenger fender. The PCM will now lift right out with ease. You could leave the harnesses attached but it causes you to have to struggle to get the PCM out of its cubby hole. You'll now see a rubber grommet in the firewall. You can fish your wire thru here. Now inside the car, go to the passenger side kickpanel, up behind the glovebox you'll find your wire. Its usually easier to remove the kick panel to find the wire.
Old Feb 25, 2003 | 11:53 PM
stik6shift98's Avatar
thats where the gf with skiny hands comes thru and feeds the wire thru....didnt even have to loosen the pcm
Old Feb 26, 2003 | 02:19 AM
GoFast908Z's Avatar
Member
Hey LS1RULZ, what that sequential turn signal thing in your sig?
Old Feb 26, 2003 | 05:54 AM
LS1 RULZ's Avatar
It blinks the tail lights in sequence pointing in the direction of the turn. It works just like the tail lights on the old Cougars used to do. I got the kit from Blink Blink.
Old Feb 26, 2003 | 09:12 AM
thats sweet did u do instlll your self?
how hard was it?
how much did u pay?
Old Feb 26, 2003 | 09:25 AM
LS1 RULZ's Avatar
Did it myself. Only took about an hour. I forget how much it was. It's been a couple of years ago now.
Old Feb 26, 2003 | 09:28 AM
do u like them?
i think its sweet
can u get a video of it?
Old Feb 26, 2003 | 09:34 AM
LS1 RULZ's Avatar
I love em. I get people asking me about them all the time. I don't have a video but they have an animated demo on the web site.
Old Feb 27, 2003 | 11:04 PM
my buddy wants to know if they have them for a transam.....
Old Feb 28, 2003 | 05:17 AM
LS1 RULZ's Avatar
Sho nuff. My car is a '99 T/A.
Sergio
Jan 27, 2016 04:27 PM
Louey
Pacific
Jan 25, 2015 12:22 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
