Big wheel?&Control arm ?
Old Feb 14, 2003 | 08:10 AM
Roadracin396's Avatar
Hey guys my name is allen.. I am ordering my rims and tires in march and want to make sure about some things first. In the front do you run the 17x11's with the same 50mm offset along with the longer studs and 1/4 inch wheel spacer. In the rear im going to go to a 335 insted of the 315 i had on it. I have irs lca's but thinking im going to have to order a smaller diamater lca to make it clear the 315's never rubed at all so i think thats all ill have to do. On the front bmr makes a upper controll arm thats adjustable but they say its a race only item. What would be wrong with running it on the street. I have a alignment machine i can use and i have done several alignments for some autocross guys. i Beleive that upper arm along with there lower controll arm will get me the caster and camber i want which is 1.5 negative camber and around 7 degrees of positive caster Has anyone used there adjustable control arms thanks allen
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
formula79
Aug 6, 2002 11:18 AM
