What could happen if i..?
Old Feb 10, 2003 | 06:13 PM
BlowBye's Avatar
Drive my camaro without a torque arm? Too make a long story short, My camaro is sitting in my garage, I just installed a 4th gen rearend. A working t-5 still sits in it, but the Torque arm mount thread is destroyed. Im installing a t-56 and Spohn adj. torque arm. What i basically need to do is move my car to my friends shop(about 15 miles from me) Can i drive it without damaging anything if drven slowly?
Old Feb 10, 2003 | 06:54 PM
IROC5.7TPI's Avatar
I have seen people rig a chain around the trans and crossmember to keep it together. I would make sure the T/A is secured before driving it that far.
Old Feb 10, 2003 | 07:10 PM
TheGreatJ's Avatar
The torque arm is the only thing that controls the pinion angle of the rear (keeps it from angling up under acceleration). Without a torque arm, the rear will twist back under any acceleration and may destroy your U-joints. You might make it to the shop, and you might not. If you can bolt it to the rear, and chain in to the tranny tailshaft or crossmember (pad it well and get it VERY tight) then you'll probably be alright. It's definitely gonna be rigged though, so don't be surprised if it makes lots of ugly noises and such.
Old Feb 10, 2003 | 07:26 PM
BlowBye's Avatar
Im well aware of the noises Since the thread was destroyed and the bolt popped out, id hear the torque arm bang against the floor pan ever time i shifted. Thanx for the help guys.
Old Feb 10, 2003 | 07:35 PM
TheGreatJ's Avatar
Just keep in mind, every time it bangs your back u-joint is goin all out of line....not good for it.
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
