My 5 speed kicks out of first.
Old Feb 5, 2003 | 07:45 PM
CamaroPower's Avatar
I'ts getting worse it kicks hard out of first. Has this happened to anyone. Could it be syncros or shift linkage or just from wear it is a 94 and I don't know how well the pervious owner took car of the car. I did replace the clutch my self about a year ago.
Old Feb 9, 2003 | 11:35 PM
Radio Joe's Avatar
Well I havent had this problem with my camaro but did with an 88 mustang I had. The 5 speeds are similar between the 2. First thing I was told to check was to pull the shifter out and check the small plastic "cup" where the shifter arm inserts in the trans (this can be done easily from inside the car.... may need to pull center console out.) Then I was told since that was okay that the trans needed rebuilt. I was able to keep it from happening very often by making sure I downshifted into first before the car came to a complete stop... Give it a try. As your rolling to the stop sign, shift into first then stop completely... that usually kept it from happening. When my mustang did it it was pretty violent....almost seemed like it would break your arm.
Old Feb 10, 2003 | 05:06 PM
Tiago's Avatar
Originally posted by robvas
If it's not the shifter, it's almost always the gears or forks.
Old Feb 10, 2003 | 06:12 PM
ibanez6rg's Avatar
Mine use to just slip out of 2nd and 4th when I would push the clutch in. It was sitting for a long time over the winter but after I got to driving it some more it stopped doing it.
guruerror
Dec 12, 2020 06:32 PM
May 1, 2015 01:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
tds1213
Nov 27, 2014 12:55 PM
